We have been looking high and low for a steering wheel cover that fits. Everything we have found so far is too big. Anyone know of a brand that will fit?
I will be keeping an eye on this thread as we've had the same issue with both our 2009 GTs. I have tried a couple different styles and brands and they've all been too big .
What year is your Vibe?
I had Wheelskins on my Olds back when I had it. They were much cheaper back then, but they were pretty nice. Except the top of my first one started cracking and peeling in the sun, so I had to replace it. Much better than the cheap hard plastic GM made their wheels out of back in the 80's.
ponta2147 wrote:I currently have a Wheelskin on my '09 and love it.
I have one on my '09 as well. Like the additional thickness it adds to the rim and additional grip in with gloves in the winter Wipe it down with leather conditioner on a regular basis and it won't dry-out of crack.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
dragon64 wrote:I have one on my '09 as well. Like the additional thickness it adds to the rim and additional grip in with gloves in the winter Wipe it down with leather conditioner on a regular basis and it won't dry-out of crack.
Would you please post a picture or two?
Okay, I have solved the issue of steering wheel covers not fitting our Vibes properly! I bought two of [url=ttp://www.bellautomotive.com/Inside-Grip-Stee ... 3138-1.htm]these steering wheel covers[/url] ($8.96 each) at Walmart for our Vibes. I also bought two 9"x12" pieces of black felt from the Crafts Department of Walmart ($0.23 each). I cut the felt into strips approximately 1"x12" and put them inside the steering wheel cover. These praticular steering wheel covers have rubber inside them that "grips" the steering wheel, so the felt is essentially held in place by the rubber. I put the strips end to end and ended up having enough to do two layers of the strips. The steering wheel cover now fits nice and snug on the steering wheel and does not slide around at all. The felt strips have also made the steering wheel feel a little more cushy then it would with just the steering wheel cover itself. I highly recommend this cheap and easy fix for anyone wanting a snug fitting steering wheel cover for their Vibe !
I bought a cover recently at Walmart ( Bell ) for 9 bucks & that sucker is on there tight. No probs & mine is an 03.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
The steering wheel covers I got for our Vibes say they will fit any steering wheel that is 14.5"-15.5". The 2009-2010 steering wheel measures approximately 14.25".
~*Nyx*~
2014 Dodge Challenger SXT V6, approx 200 miles
SOLD - 2006 Pontiac Vibe Base 1.8L, 62k miles
SOLD - 1996 Pontiac Firebird V6, 94k miles
SOLD - 2004 Pontiac Sunfire 2.2L, 45k miles
SOLD - 1989 Pontiac Grand Am V6, 100k miles
