turbo questions read help
Posted: Sun Aug 21, 2011 10:56 am
by vibe13
hello guys im looking follow to get a turbo on my vibe 03 i keep hearing for other people i need some kinda of piston because my engine could BLOW UP IF I DONT ! IS IT TRUE OR NOT? IF ITS TRUE please tell me where to get them at ? and else what kinda of turbo could be good for my vibe thanks !
Re: turbo questions read help (vibe13)
Posted: Sun Aug 21, 2011 11:46 am
by A Psycho Martyr
ever thought about a supercharger? or are you stuck on the turbo?
Re: turbo questions read help (A Psycho Martyr)
Posted: Sun Aug 21, 2011 9:51 pm
by vibe13
How does the super chargers? Works never saw on any car before can you give me some info about it thanks
Posted: Sun Aug 21, 2011 10:00 pm
by KITT222
Kiethvibe has a Vibe AWD that he turbocharged, and he didn't need new pistons. The only thing done on the engine as far as replacing parts, was that he got injectors from a 2zz engine (Vibe GT/Corolla XRS/Matrix XRS. Vibe AWD has the 1zz engine).
http://forums.genvibe.com/zerothread?id=44394
Posted: Sun Aug 21, 2011 10:38 pm
by Salsa Guy
No you don't need new pistons! However before you go slapping a Supercharger or Turbocharger on a 11 y/o engine you should run a compression check first to make sure everything is in good shape. Also be prepared for MORE maintenance, lower fuel economy, cost of the setup and stuff breaking. Any amount of boost can blow your engine if not properly "tuned". I assuming you have the 1zz engine.Forced Induction 101TRD Supercharger Kit is easy to install (about 8 hours) and comes with a pre-tuned TRD piggyback ECU. There are some used Kits floating around and the condition can vary. The SC runs off the engine serpentine belt. Turbo Chargers Kits are harder to install and require some expertise. You also need to have ECU piggyback and have someone "Tune" it. The Turbo runs off of exhaust gases and are a bit more fuel efficient. If you think about buying some E-bay Turbo kit and slapping in on and not doing any ECU tuning you'll blow your engine in no time.
Re: turbo questions read help (Salsa Guy)
Posted: Mon Aug 22, 2011 12:35 am
by vibe13
2zz is a bigger engine and faster right then 1zz because that's what have right now
Posted: Mon Aug 22, 2011 5:02 am
by Salsa Guy
Quote, originally posted by vibe13 »2zz is a bigger engine and faster right then 1zz because that's what have right nowGoodluck with your project!
