Another P0171 question
harryb
Postby harryb » Sat Nov 20, 2010 5:36 am
I've had the P0171 code before on my 2006 Vibe. The first time, the O2 sensor was replaced. A couple of months later, the CEL came on again, and this time (different mechanic), I was told it was probably just the MAF sensor needing cleaning. They did so, and everything was fine for several months. It came on again about 3 months ago. This time I cleaned the MAF sensor myself, using a can of MAF sensor cleaner. Now, about a week ago, the CEL came on again. I had Autozone pull the code, and it's P0171 again. I can clean the MAF sensor again, but I'm thinking there must be something else going on, the sensor should be pretty dang clean by this point. Ideas?
Thanks,
Harry
2006 Vibe
Raven
Re: Another P0171 question (harryb)
Postby Raven » Sat Nov 20, 2010 7:07 am
My '06 throws this code every couple of months. Usually after a long drive at sustained highway speeds (60-70mph).
When I reset it with my code reader it does not come again for a month or two.
I have a Cosmo CAI and Magnaflow exhaust which I thought may have an effect on the situation.
Try using a bottle of Techron fuel system cleaner, it has worked magic for me in the past.
j1yuan
Postby j1yuan » Tue Nov 23, 2010 9:02 pm
P0171 shouldn't be caused by O2 sensor according to this web page at RepairPal.com --> http://repairpal.com/OBD-II-Code-P0171-and-P0174
Here is my P0171 story, of course it may or may not be the same as yours --> http://forums.genvibe.com/zerothread?id=42978
05 Vibe base, bought in May 2010
j1yuan
Re: Another P0171 question (Raven)
Postby j1yuan » Tue Nov 23, 2010 9:04 pm
I agree that one should reset the code when one sees fit. You can buy a cheap code reader for $30 or so.
harryb
Re: Another P0171 question (j1yuan)
Postby harryb » Tue Nov 23, 2010 10:32 pm
[QUOTE=j1yuan]P0171 shouldn't be caused by O2 sensor according to this web page at RepairPal.com --> http://repairpal.com/OBD-II-Code-P0171-and-P0174
That's pretty much what the repair guy told me. Since I've cleaned the MAF sensor three times now, is it time to consider replacing it? How do you know when it's actually gone bad? I'm at about 70,000 miles, BTW.
2006 Vibe
j1yuan
Postby j1yuan » Wed Nov 24, 2010 1:37 am
Quote, originally posted by harryb »
When you cleaned it, was the MAF sensor dirty? If it was, why? You have to prevent it from becoming dirty.
In my case, the problem was caused by the air cleaner casing which wasn't closed properly (by the previous owner). Once I close it properly, the MAF sensor never becomes dirty again.
harryb
Postby harryb » Tue Nov 30, 2010 10:32 am
Now, the weather has turned cold (40s) and the CEL has gone off.
Harry
2006 Vibe
Raven
Postby Raven » Sat Dec 04, 2010 9:27 pm
Mine was on again Friday, I reset it.
Azem
Postby Azem » Thu Dec 20, 2012 10:45 am
Have similar problem... 2006 Pontiac... Cleaned sensor few times, CE come back, Was recall for change PCM, CE come back... Today checked L-shape hose attached to the intake big rubber hose and viola! It comes out easy, so it was not installed properly on the beginning... Before I may see the shoulder of the small hose, after I pressed it firmly down the shoulder stopped by flange of the hole of the big rubber intake hose making better seal. I believe this was original problem! :lol: :roll:
Return to “Problems & Warranty Issues”
Who is online
Users browsing this forum: No registered users and 0 guests
