Vibe GT won't start - Need diagrams/instructions to replace starter
kicknrim
Post by kicknrim »
My son has the Vibe GT in Virginia and told me a month ago that occasionally the starter sounded like it was missing (plunger or relay?). Today he called and said he killed the car and now it won't start at all. All the gauges are on, lights are bright, and it's a pretty new battery. Anyway, school is expensive and I need to walk him through removal of the starter so he can have it tested. Anyone have a link to diagrams or instructions for locating and removing the starter on these? Simple testing procedures would be good too for checking the relay (where is?), solenoid (where is?), then starter (where is?). Thanks in advance.
keithvibe
Re: Vibe GT won't start - Need diagrams/instructions to replace starter (kicknrim)
Post by keithvibe »
welcomecheck this threadhttp://forums.genvibe.com/zerothread?id=40209
welcome to genvibe. Tell your son to stop by too.at least it's a manual tranny. Tell him to be sure to always park on a hill the thread keithvibe linked has the starter removal/install procedure
Here is the starter and starter relay test procedure
x040001.pdf
starter replacement
(16.08 KiB) Downloaded 130 times
inspec40.pdf
test procedure
(36.98 KiB) Downloaded 134 times
Re: Vibe GT won't start - Need diagrams/instructions to replace starter (joatmon)
Here is the starter assembly diagram
conponen.pdf
(30.18 KiB) Downloaded 103 times
starter overhaul procedure
w040001.pdf
(126.69 KiB) Downloaded 88 times
starter circuit wiring diagram
013ss.pdf
(30.25 KiB) Downloaded 142 times
The starter relay in on the top side of the under dash fuse block, you should be able to access it by pulling out that small storage bin left of the steering wheel (below the mirror/dimmer control)
kicknrim
Post by kicknrim »
All. Incredible. Will let you know how it goes. Thanks.
bodhi_tree777
Re: (kicknrim)
Post by bodhi_tree777 »
Good luck! This forum is amazingly helpful, especially for a Vibe driver on a budget. Tell your son to set himself up an account and the folks here can usually help out with almost any troubleshooting or DIY projects he may want to tackle. I can't even tell you how much money this site has saved me just in simple procedures like DIY brake jobs, changing tranny fluid, changing the rear wiper and on to slightly tougher stuff like rebuilding a brake caliper.
