OBD II Scan Tool
dcbridgwater
OBD II Scan Tool
Postby dcbridgwater » Fri Jan 22, 2010 3:42 am
If your going to buy an OBDII scan tool which one would you get?
I am considering buying Actron CP9185 or Equus Innova 3160. Has anyone used either of these or can suggest something better?
Thanks in advance,
Dale
2006 Neptune AWD
Side & Curtain Airbags
ABS
Power Package
Cruxless
Re: OBD II Scan Tool (dcbridgwater)
Postby Cruxless » Fri Jan 22, 2010 4:29 am
I haven't used either of those but I love my Scangauge II.
http://www.scangauge.com/
BlueCrush
Postby BlueCrush » Sat Jan 23, 2010 3:59 am
I have used Actron for years. I have a CP9125 OBD-II Scanner CP9449 ABS BrakeScan. They have saved me thousands of dollars by being able to diagnose pull the CEL and diagnose the problem myself, buying my own parts and installing it myself or having a local trusted shop do it vs. going to a dealer.
Herb
Postby Herb » Sat Jan 23, 2010 4:15 am
I like the Scangauge II as well, so many more functions besides code scanning
Would you agree to debris acceptance?
2003 Vibe GT
Mods installed
GM Top and Mid-Gate Spoilers, Cosmo CAI, TWM Short Shifter with Desert Eagle weighted shift knob, TWM Bronzoil Shifter Cable Bushings, Magnaflow Cat Back Exhaust, Unichip, Injen Billet Aluminum Engine/Sparkplug covers and oil cap, Optima RedTop Battery, Lineage Ground Wire Kit
Awaiting install:
Energy Suspension Motor Mounts, DC Sports Header
zionzr2
Postby zionzr2 » Sat Jan 23, 2010 7:06 am
another for scangaugeII
Old Tele man
Postby Old Tele man » Sat Jan 23, 2010 10:32 am
...I have both, an Actron CP9135 OBDII AutoScanner handheld unit and an in-car ScanGaugeII.
...the Actron is better for diagnosing problems, while the SGII is better for daily driving information, although the SGII can do almost everything the Actron can, just in different manner. Also, since there's only only OBDII plugin location, the SGII is "always ready" since it's already plugged in and ready to use.
...nevertheless, IMHO, the Actron provides more detailed and informative information.
• 2011 Cruze LTZ 1.4LT 6A
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
Return to “Tech Info & Do-It-Yourself Info”
Who is online
Users browsing this forum: No registered users and 1 guest
