Registry Updates
Posted: Mon Dec 28, 2009 12:53 am
by mkowdley
Hello all, The GenVibe.Com Registry
http://www.genvibe.com/cgi/registry/registry.cgi has been updated to use the same login as your forum account.If you don't have a forum account already, you will need to create one before you can update your registry again.When logging into the registry, use your forum username and password. The first time through, you will get an extra form that allows you to link your forum account and registry account by entering in your forum username, forum password, old registry username, and old registry password. After you've done this, you can access your registry using your forum username and password, and you will not need your old registry username or password any more. Also, a link to your registry will be shown under your name in any posts you make on the forums.If you have any problems with the linking process, post them here and I'll try to assist.
Re: Registry Updates (mkowdley)
Posted: Mon Dec 28, 2009 1:03 am
by BlueCrush
After linking my old registry to my forum account sucessfully, I get a 404 Not Fount Error:Quote »NOT FOUNDThe requested URL /cgi/registrydev/details.cgi was not found on this server.Apache-AdvancedExtranetServer/2.0.53 (Mandriva Linux/PREFORK-9.2.102mdk) PHP/4.3.10 mod_jk/1.2.6 Server at
http://www.genvibe.com Port 80
Re: Registry Updates (BlueCrush)
Posted: Mon Dec 28, 2009 1:23 am
by mkowdley
Quote, originally posted by BlueCrush »After linking my old registry to my forum account sucessfully, I get a 404 Not Fount Error: Okay, this is fixed. You may need to clear your browser cache (the reload button is sufficient for Firefox, but maybe not IE) to load the patched javascript and see the correct result.
Posted: Mon Dec 28, 2009 1:25 am
by BlueCrush
Yup, it works now. Thanks!
Posted: Sun Jan 03, 2010 5:05 am
by BlueCrush
I am unable to add a photo to the registry home page and get this error when I click on it: The requested URL /cgi/registry/photoinstruct.htm was not found on this server.Apache/2.2.3 (Red Hat) Server at forums.genvibe.com Port 80Thanks!
Posted: Sun Jan 03, 2010 5:12 am
by BlueCrush
Quote, originally posted by BlueCrush »I am unable to add a photo to the registry home page and get this error when I click on it: The requested URL /cgi/registry/photoinstruct.htm was not found on this server.Apache/2.2.3 (Red Hat) Server at forums.genvibe.com Port 80Thanks!Got it figured out. You need to add a photo in the Registry Update.
Posted: Sun Jan 03, 2010 5:38 am
by keithvibe
I set mine up the other day but didn't see it show up yet in my profile section yet. I'll follow the info here and see if that helps clear up the issue.Edit:nope can't get it to show up overI've cleared my history, my forum cookies, ect. Is there something I'm missing to keep it from showing up over
Re: Registry Updates (keithvibe)
Posted: Sun Jan 03, 2010 6:18 am
by BlueCrush
I saw it missing on a few members posts.
Posted: Sun Jan 03, 2010 4:23 pm
by mkowdley
Quote, originally posted by BlueCrush »Got it figured out. You need to add a photo in the Registry Update. Thanks, I will fix the link.
Posted: Sun Jan 03, 2010 4:41 pm
by mkowdley
Quote, originally posted by keithvibe »Edit:nope can't get it to show up Okay, I fixed it. There was a bug when creating your registry that didn't link it properly to your forum account. I fixed the bug and manually linked the two. New users won't have any problem (hopefully), but users who recently created registries may also need to have the accounts manually linked by me. Let me know in a forum PM if you need this.
Posted: Sun Jan 03, 2010 7:36 pm
by keithvibe
ty.
Posted: Tue Jan 05, 2010 11:35 pm
by 06pvibe
Quote, originally posted by mkowdley » Okay, I fixed it. There was a bug when creating your registry that didn't link it properly to your forum account. I fixed the bug and manually linked the two. New users won't have any problem (hopefully), but users who recently created registries may also need to have the accounts manually linked by me. Let me know in a forum PM if you need this.It must have worked because I had no problem registering our Vibe or installing a picture link. However, it does seem that we are not allowed to buy our cars in December? FYI: I had to say that we got ours in January, because of no December option on the drop-down.
Posted: Mon May 03, 2010 11:25 am
by AdmRose
Whenever I try to update my registry information it gives me an error message that all photo URL's must begin with http:// even though I didn't type anything into the box. As a result it won't let me update it.
Re: (AdmRose)
Posted: Mon Jun 07, 2010 5:59 am
by mkowdley
AdmRose - is this still an issue?
Re: (mkowdley)
Posted: Mon Jun 07, 2010 6:31 am
by AdmRose
Quote, originally posted by mkowdley »AdmRose - is this still an issue?No all I had to do is upload a picture and the update work, but if I had chosen not to do so then it still would have been an issue. Basically it won't let you update without a picture URL.
