Code help P0607
Can0beans
Code help P0607
Postby Can0beans » Sat May 09, 2009 10:03 am
Today my 2006 Vibe, which has been pretty good to me except sometimes cranking longer than I think it should on start, decided to lose all power and act like it was going to stall. I was able to drive it at idle speeds and get it off to the side of the road. The check engine light came on at the same time. I let it sit for awhile and it started running just fine (with the check engine light on). Took it to autozone and got the codes off of it. Only one showed up P0607 Control Module Performance.
Can anyone help me figure out what is wrong?
ou.grizzly
Global Moderator
Re: Code help P0607 (Can0beans)
Postby ou.grizzly » Sat May 09, 2009 10:05 am
Call your dealer and make an appointment. Sounds like the ECU is going. It is covered under the 80,000 mile emissions warranty.
Can0beans
Postby Can0beans » Sat May 09, 2009 10:07 am
Should I avoid driving? Is it likely to leave me stranded?
ou.grizzly
Global Moderator
Re: (Can0beans)
Postby ou.grizzly » Sat May 09, 2009 10:19 am
Quote, originally posted by Can0beans »
It can leave you stranded... Your gamble. If you have access to another vehicle to use tomorrow until the dealer opens on Monday, do not use the Vibe.
Toasted7
Re: (ou.grizzly)
Postby Toasted7 » Sat May 09, 2009 5:02 pm
It WILL leave you stranded... get it to your dealership asap. They will replace the PCM, I just had mine replaced last week... for the 4th time!
Can you say lemon?!?
VMFIC of Cincinnati Scikotics
Cincinnati Scikotics sponsored by: KerryScion.com
My other ride is your mom
Can0beans
Re: (Toasted7)
Postby Can0beans » Sun May 10, 2009 11:34 pm
Made the appointment this morning, unfortunately they couldn't get me in till Thursday.
Anything I should make sure to tell the dealer to insure they replace the module? I'm concerned they will come up with something not under warranty that they want to fix.
Also, I think I read that there was a TSB about this, am I remembering correctly? If so, are TSB's available online?
Toasted7
Re: (Can0beans)
Postby Toasted7 » Mon May 11, 2009 12:18 pm
The should read that code and replace the PCM with no questions asked. Mine left me stranded and I had to tow my Vibe to the dealership... that's why I may not be a Vibe owner much longer.
Return to “Problems & Warranty Issues”
Who is online
Users browsing this forum: Exabot [Bot] and 0 guests
