Quote, originally posted by northvibe » |
ABS is really for lazy americans |
OUTER REAR VIEW MIRROR ASSY LH
REPLACEMENT
HINT:
Installation is in the reverse order of the removal.
In the RH side, work in the same procedure as in the LH side.
1. REMOVE FRONT DOOR PULL HANDLE LH (See page 75–5)
2. REMOVE POWER WINDOW REGULATOR MASTER SWITCH ASSY (W/ POWER WINDOW)
(See page 75–5)
3. REMOVE FRONT ARMREST BASE PANEL UPPER LH (W/O POWER WINDOW)
(See page 75–5)
4. REMOVE FRONT DOOR WINDOW REGULATOR HANDLE ASSY (W/O POWER WINDOW)
(See page 75–5)
5. REMOVE FRONT DOOR LOWER FRAME BRACKET GARNISH LH (See page 75–5)
6. REMOVE FRONT DOOR TRIM BOARD SUB–ASSY LH (See page 75–5)
7. REMOVE OUTER REAR VIEW MIRROR ASSY LH
(a) Remove the 3 nuts and the rear view mirror assembly LH, and then disconnect the connector.
8. INSTALL OUTER REAR VIEW MIRROR ASSY LH
Torque: 8.0 NVm (81 kgfVcm, 71 in.Vlbf)
HIS - 03' SALSA TWO-TONE MOON & TUNES
HERS - 04' FROSTY WHITE BASE
[IMG][/dscf0205]
Also could someone help me with removing the passenger door panel?
Thanx for your quick replies!
Quote, originally posted by asagorcus » |
I may be able to help you...but i have to accomplish my task first. Also could someone help me with removing the passenger door panel? Thanx for your quick replies! |
Refer to Cohocarl's thread on how-to-install-speakers which you were looking at earlier.
That was for the rear door panels does that apply to the front door panels as well? |
Pretty much...
So yeah just follow the directions. :-P
Alright everything went smoothly! Thanx for your help everyone! So yeah just follow the directions. :-P For the person that was inquiring about the old mirror email me at: asagorcus@gmail.com Once again thanks for the help! |
Your welcome... May the force be with you.
Return to “Tech Info & Do-It-Yourself Info”
Users browsing this forum: No registered users and 1 guest
