Lug Nut (re)Torque
Lug Nut (re)Torque
I just wrote Pat Goss a note. Here is his reply back to me:
Me: Whenever I go to get my tires rotated, I always receive a piece of paper stating I should return to have the torque of the wheel nuts checked after 25 miles. Is this really necessary? Can the wheel nuts really loosen up significantly on their own?
PG: Thanks for watching! I presume you’re dealing with a dealership or chain store and at some time they had a wheel come off a customer’s car. Once that happens or they hear about it at another shop legal steps in and has the shop institute this notification. Other than a few (now) quite old cars with a specific type of alloy wheel this rarely happens. But due to the nature of dealership and chain store techs (often very low skill levels) wheels may not be properly tightened from the beginning, so they loosen as you drive. But again, it is mostly a way to prevent a customer from having grounds for a lawsuit, “Your Honor we gave them a clearly worded notice and they didn’t follow it so it’s their fault not ours.” Their fault even though we let them leave our shop with improperly tightened wheels.
Re: Lug Nut (re)Torque
In the infrequent event a tire shop touches my cars nuts, I always re-torque them when I get home. I haven't seen a problem for 20 years or so, but back then the one I went to (Sears) would way over-torque. I had a little econocar and one would often break when I loosened it. I wanted to fix it at home rather than on the road.
It is absolutely just a liability thing. However, like andrewclaus said, I have always checked mine when I returned home.
I confess to having never done this, but if its a liability thing, I guess I ought to in order to prevent me from suing myself. So, stupid question, in retorquing, do you loosen and retorque one nut at a time or do you just ensure they are still at least as tight as they are supposed to be?
I just make sure they're wrench tight with a regular ratchet, or the lug wrench from the spare compartment. Actually I triple check, once more after I clean up and am closing up shop. At that point it may be one nut per wheel.
Maybe you can tell I made that mistake once, a lifetime ago, and never want to do that again.
I bought a torque wrench at Walmart a long time ago and have always checked my cars after a tire rotation and before heading on a long trip. Obviously you can't just "torque forward" because if the lug is severely over torqued (which is what you are trying to avoid), you'll just get an instant double click. So logically you have to back the nut off and retorque each one to your owner's manual setting. Over the years, I have found some that were over torqued and occasionally a few that were pretty loose, all determined by how easy or hard it is to back the lug nuts off. I'll never know which ones were spot on. Also, by checking each one myself, I can determine if the shop cross threaded a stud (which they do all the time). I have had studs replaced on all of my cars over the years due to a "mechanic's" negligence. I certainly would rather find out about the cross threading in my driveway instead of on the side of the highway while changing a flat tire.
Mark
Post by Mark »
The guys at my tire shop seem to really hate the Toyota 76 ft/lb torque setting, one even told me they thought 100 should be the minimum on all wheels. They swear they hand torque to 80 on my cars but I always find one nut per wheel that's at least 100. Never have had a loose or cross threaded one, knock on wood.
I checked on my daughter's Frosty a couple years ago, and one nut on the right rear I couldn't bust loose with my cordless impact. I grabbed a 1/2" drive 20" breaker bar and pulled until the rear tire spun sitting on the floor. So I drove back to the shop, got the little tire tool out of the back, and had the shop manager try to break it loose. He couldn't do it so he called all three of the tire guys up and had them try, two failed and the third one finally got it, but he turned the wrench over and used his foot. How is my daughter, who is maybe 100#s, going to change that tire on the side of the road?
jolt
Post by jolt »
Sad to say but most tire shops just run the wheel nuts on with a air impact gun. They do not check torque, and if they do, it is just to check that the torque is up to the minimum. They do not know if the nut / stud are over torqued. This is a great way to damage the nut and stud. It can also warp the brake rotor and/or hub if not tightened evenly or in stages like 30 ft-lb, then 50 ft-lb, and finally 76 ft-lb.
vibedrivermatt
Post by vibedrivermatt »
Old thread I know but I'm bumping becuase this is an interesting topic.
I know how tight to torque my wheels as I change them twice a year. I used to use a torque wrench but that takes a long time. Lately I can guestimate pretty well when I have about 80 90 ft lbs.
One thing that irks me is when I find the wheel that the inspection shop removed. It's always torqued on way too tight and difficult to break the lug nuts looks. They just torque it to desth with their impact gun.
Mark
Post by Mark »
I used to break and re-torque every lug nut after I had the tires rotated. Tire shop guys seem to just hate 76-80 ft/lbs, anything less than 100 is too little, and 120 should be the standard I think is how they view it.
Now I have one guy at the shop who knows that I want 80 and not anything else on my Vibes. Every once in a while another guy gets it and I'll have 4 lugs at 80 and one at 100-120. One time I found one that I couldn't break loose so I stopped trying and took it back. I got the little lug nut wrench out of the back and got the service manager to make the tire guys try to break it loose. One finally did, but it took some grunting. I explained that this is my daughter's car. She weighs 95 lbs soaking wet, how the hell is she going to change a flat on the side of the highway when you guys do this crap? This is Wyoming, a tow truck can be 2+ hours away, assuming you even have cell service. Idiots.
I drove a cheap import back in the late 80s, with 4 lugs/wheel. I also made a habit of loosening the lugs after a tire change, and a couple of times I showed the service manager stripped bolts and had the shop replace them. Because of those incidents, the shop started using torque limiters.
