The check engine light is not on ,will there still possibly be codes storedandrewclaus wrote: ↑Sat Feb 15, 2020 12:49 pm See if there are any pending codes in the OBD system.
It sounds like the temp sensor isn't reading right. Is your coolant full? Thermostat working correctly?
the check engine light is not on will there still be codes stored
Pending codes and past codes will be stored until reset.Beetle736 wrote: ↑Tue Feb 18, 2020 12:58 pmThe check engine light is not on ,will there still possibly be codes storedandrewclaus wrote: ↑Sat Feb 15, 2020 12:49 pm See if there are any pending codes in the OBD system.
My Vibe has 185000 and I have never replaced my intake gasket,I will be doing it in the near futureSeattleJeremy wrote: ↑Tue Feb 18, 2020 2:28 pm Has the intake manifold gasket been replaced? The factory gasket did not hold a good seal when it's cold out, and Toyota had to redesign the gasket a few times to get it right. My car would stall when it was cold out too until that gasket was replaced.
I scanned for any codes there were none stored ,coolant is full ,appears thermostat is working properlyandrewclaus wrote: ↑Sat Feb 15, 2020 12:49 pm See if there are any pending codes in the OBD system.
Yes check coolant level. Another first check.
