You looking for anything in particular?
I can see it now. A box with one rear headrest, the glove box door, coin holder from next to the steering wheel, and the rug from the bottom of the console
I was thinking more like a slightly used cabin air filter, the fan speed knob, the wingnut that holds the jack in place, one of the side cargo area compartment covers, and the little stick that holds up the hood.
Heheh.mktrat wrote: ↑Fri Feb 15, 2019 6:22 amI was thinking more like a slightly used cabin air filter, the fan speed knob, the wingnut that holds the jack in place, one of the side cargo area compartment covers, and the little stick that holds up the hood.
Single but FYI the latch is broken. Otherwise, it's fully functional.Bookworm wrote: ↑Fri Feb 15, 2019 10:31 amHeheh.
For yourself, be sure to yank out the door actuator motor so you have a spare (plus the knobs I mentioned earlier)
I'll try to come up with a short parts list myself. Does your center console have a single lid, or the double lid?
I’ll make sure to box that one up!!Bookworm wrote: ↑Fri Feb 15, 2019 12:50 pm The HVAC door actuator - that's the motor that opens and closes the recirculation vent door. It's one of those parts that I think every single Vibe ends up having break within 7 years, due to several poor designs. If you work your way behind the glove box and remove it, you'll have it for _when_ yours breaks in the current Vibe. (you can even flip the gear over to get extra life out of it)
