Same thing applies to 5.4L Ford pickups. That is why a tuneup at the dealership cost ~$850.00. They know the coils packs will start to go like popcorn popping, so they just say to replace them all at the same time while they have it apart. If the customer does not want to spend the money and replace all the coils, then it is the customers problem and it will cost more later. It is funny that the coils last as long as they do when you think about the coil sitting down in the engine on top of the spark plug and how hot it gets there. Old coils use to sit out in the open and were oil filled to help reduce heat. They also did not put out the high voltage that the new coils do. Coil packs now are just considered a tuneup part; like spark plugs. New car tuneup every ~100,000 miles vs. old car tuneup every ~12,000 miles. The coil packs are cheap when you look at the cost over the life time of the car vs an old '70-'80's car tuneup costs.Caretaker wrote:while I can't speak to these Toyota engines, from my research on the Honda boards, I do know that it would be a mistake to replace just one ignition coil. Replacing all four (with Denso) in conjunction with the spark plugs is just something we have to endure when the time comes.
Speaking of F150's. On my truck I had to replace just the boots and springs in the coils. Can that be done on these cars? I haven't taken mine apart yet, just got it.jolt wrote:Same thing applies to 5.4L Ford pickups. That is why a tuneup at the dealership cost ~$850.00. They know the coils packs will start to go like popcorn popping, so they just say to replace them all at the same time while they have it apart. If the customer does not want to spend the money and replace all the coils, then it is the customers problem and it will cost more later. It is funny that the coils last as long as they do when you think about the coil sitting down in the engine on top of the spark plug and how hot it gets there. Old coils use to sit out in the open and were oil filled to help reduce heat. They also did not put out the high voltage that the new coils do. Coil packs now are just considered a tuneup part; like spark plugs. New car tuneup every ~100,000 miles vs. old car tuneup every ~12,000 miles. The coil packs are cheap when you look at the cost over the life time of the car vs an old '70-'80's car tuneup costs.Caretaker wrote:while I can't speak to these Toyota engines, from my research on the Honda boards, I do know that it would be a mistake to replace just one ignition coil. Replacing all four (with Denso) in conjunction with the spark plugs is just something we have to endure when the time comes.
metalgeeksolid wrote:Update:
My mechanic diagnosed the faulty ignition coil which has been replaced. However, when we started the car up, the battery light now comes on and goes away after a few seconds. He's going to take the alternator and battery to get them tested and also change the battery connectors for me since they look bad.
Is this a pure coincidence that the battery light came on after changing the ignition coil? I find it odd that the light just now pops up when it never did before.
