OBDII scanner
KingKrab65
OBDII scanner
Post by KingKrab65 »
I am looking to purchase an OBDII scanner. I need a hand held version as I do not have a laptop or phone that I could hook it up to. I recently got a CenTech one but that didn't read the code. It only canceled the MIL, so I returned it.
Has anyone in this group had any luck with a particular model of OBDII scanners?
Thanks for the input!
2003 Base Vibe
jayoldschool
Re: OBDII scanner
Post by jayoldschool »
Just get a used Android phone, or a cheap Android tablet at WalMart, and run Torque. Combined with a $15 Bluetooth adapter, you'll do more than a cheap scanner.
petervivian
Re: OBDII scanner
Post by petervivian »
jayoldschool wrote:Just get a used Android phone, or a cheap Android tablet at WalMart, and run Torque. Combined with a $15 Bluetooth adapter, you'll do more than a cheap scanner.
I paired my $5 ebay scanner with a $10 Bestbuy locked Android phone. This solution works great.
Vulcan05
Re: OBDII scanner
Post by Vulcan05 »
Check out a ScanGuage. I have one that is now in the third car since I bought it. Works great and gives 4 readouts at a time as well scans for problems. No phone needed.
2010 Vibe. Moon roof, Monsoon, 2.4 engine, 5 speed auto, cruise, dark gray.
JetBlack
Re: OBDII scanner
Post by JetBlack »
Check out SlickDeals or KinjaDeals was able to find some very inexpensive OBD2 scanner there. Peronally since I use iPhone I've gone with WiFi scanner and OBDcardoctor app. The Scanner ran me $8 and the app is free you should be able to view live data and Error codes.
Join the VibeTribe on Drive Tribe https://drivetribe.com/t/LGVEe7TeQceVCW ... rTPsS40_rQ
2009 Vibe 2.4l Premium Package w/ Roof Rails
MacGyver
Re: OBDII scanner
Post by MacGyver »
I have this one, except in Canada they are sold under the Autel brand.
https://www.harborfreight.com/automotiv ... 62142.html
2009 Vibe Base
KingKrab65
Re: OBDII scanner
Thanks to everyone for all the great suggestions. There are some good choices here that I will check out.
Thanks again for everyone's help!
2003 Base Vibe
Re: OBDII scanner
I have been meaning to look into getting an OBDII scanner for a while now, so this post was just the boost I needed! I just bought the Cen-Tech one that MacGyver mentioned, for $22.99 shipped from eBay.
KingKrab65
Re: OBDII scanner
MacGyver wrote:I have this one, except in Canada they are sold under the Autel brand.
I ended up getting the Autel version of this from Amazon. It is a pretty basic reader and it actually gives me code info. It does not do the ABS reading but that's OK for now.
Thanks again for everyone's suggestions!
2003 Base Vibe
Re: OBDII scanner
Ultra cheap code reader that works fine.
https://www.ebay.com/itm/254320957576?ul_noapp=true
