Since couples of weeks, im getting real poor efficiency per refill. I'm only getting 350km per tank wich is pretty bad consideringi would normally get 550km per refill in highway conditon. Does any one have a clue on what should be verified in order to correct this issue. So lately, I changed the spark plugs but it seems like the overall Km is pretty much the same after a week of driving it back and forth...
Assuming you fill up about 10 gal (US) you are only getting 21.7 mpg and you used to get 34 mpg. That's a huge drop. And it also seems to be sudden.
Did you change the way you use the car? Are you doing more short distances and cold starts? Are you encountering more and extended periods of idling? Are you accelerating harder than usual?
Goodnite mates,
Well let say my actual driving is pretty much the same every day. Im using it as a daily commuter from where I live to where im working at kost of the time.... highway 100 to 120km/hr.... recently i tried dumping a injector and valve cleaning kit in a fuel tank of the supreme blend without much results.but comparable and very average mpg.... im therefore thinking a clog maf sensor, throttle body valve.failure or goingnto have to figure out myself how to perform a compresion cylinder test..... if any of you know the trick about the last keep me updated.... goodnite
What year is your Vibe? Which engine does it have? What transmission does it have? Is it an AWD or two wheel drive? Does the engine come up to full temperature? Does the transmission go into overdrive? Does the torque convertor lock up if you have an automatic transmission? Does the car roll freely on flat ground? Do you the "check engine" light on? Are there any codes stored in the ECM?
Hello everyone,
Since a long time that red vibe beater is providing some realy bad mileage per tank. My car is a 2006vibe standard and it does actually 300km/per tank runned on syntjetic oil... might bw thebrake dragging will upgrade front and rear brake n3xt couple of week does anyone out there have any suggestion on what should be checked or changed? I you have any clue let me know.
