Shifter bushings
Fatpaul
Shifter bushings
Post by Fatpaul »
I looked around and couldn't find a post about how to change these out, I just bought a tcs kit and would love for some how to! 2008 vibe base 5 speed manual
ImUrOBGYN
Re: Shifter bushings
Post by ImUrOBGYN »
You should be able to see the cable underneath. I'm not sure on the 2008, but jacking up the car and removing the front driver side may help. After that, I just started prying. One came out easily, one did not. :x
Pro tip: Changing the shifter base bushings had a more profound affect for me than the shifter cable bushings. Like them both, however. :)
Fatpaul
Post by Fatpaul »
ImUrOBGYN wrote:You should be able to see the cable underneath. I'm not sure on the 2008, but jacking up the car and removing the front driver side may help. After that, I just started prying. One came out easily, one did not. :x
Yeah I bought the base bushings, Where do I start?! 8-)
sideshowalan
Post by sideshowalan »
This is a great guide on how to remove the shifter. It's the install instructions for the TWM short shifter.
http://www.twmperformance.com/manuals/m ... manual.pdf
2008 Pontiac Vibe
2008 Toyota Sienna XLE
Fatpaul
Post by Fatpaul »
sideshowalan wrote:This is a great guide on how to remove the shifter. It's the install instructions for the TWM short shifter.
I like this but am I blind to where they go?!
sideshowalan
See the large white plastic mount on page 7? It's attached to the rest of the car by a few bolts. The new bushings replace the old ones that are sandwiched between the bolts and the car.
2008 Pontiac Vibe
ImUrOBGYN
Post by ImUrOBGYN »
Don't forget you can follow the Repair Manual; Section 41-005 or 41-5 is where the floor shift lever assembly craps begins.
And here's a couple pics from that section to show the bushings. Of course, if you're using the actual manual and see the section as a whole, it'll help put it more into context.
You can see the 4 base bushings here where I cut it out from above.
Fatpaul
Post by Fatpaul »
Thanks a lot for the info y'all!! Going in tomorrow
