Yes, fully loaded. Not sure if GPS was an available option but no GPS on mine.SeattleJeremy wrote:Welcome to GenVibe!
Does the car have power windows and door locks? If so then it should also have remote keyless entry. Unlocking the car will also unlock the rear-hatch.
Thanks for the warm welcome!vibenvy wrote:Welcome to GenVibe! That's a very sharp looking 1st gen Lava GT you've got there! Thanks for posting pictures of it right away !
Really? That would be great if possible, but I thought it would not work since it has a manual transmission and no way to signal the locks to lock. I thought it was the Park and Drive on the automatic gear selector that triggered the auto unlock and lock.Salsa Guy wrote:There's also a way to set the Auto Lock Mode during that Programming process.
Budget Matrix Intakevibenvy wrote:Glad to hear you've added some fun goodies and also dealt with some issues you were having. Now, post some updated pictures with the new mods for us to enjoy !
Link for ebay $32 shipped!SirLinux wrote:Where did you get that air intake and how much was it? Is there much difference in performance over the stock intake?
BTW - the color of your GT looks great.
Regards.
Thanks for the heads up I will look into that too. Maybe I will just go ahead and order the mounts so they are here for the clutch job.mikevibegt wrote:Nice vibe gt, I am own 03 vibe gt also,I like you vibes color.Just a little heads up you may find out that some of your motor mounts are worn out, a lot of cracks in the rubber, I replaced all of mine when i did clutch, because all but one will be disconnected anyways during clutch change.Enjoy your car, and have fun working on it.Keep us posted on your project, also like interior wrap.Good job
Comes with everything you need except the car specific radio harness adapter (you will need the Metra adapter for our car)plausipo wrote:Hi,
I am thinking about changing out the stock radio (04 vibe base) with a similar Android 4.4 thingy. Does your new stereo comes with all the electrical/antenna/mechanical connectors to "plug and play" or you need to cut/splice wires and add GM adapters to make it work?
Po
I replaced all the shocks so its holding good. A bit jumpy on roads that are messy highway and good surface roads rides like my IS350 very smooth.cptnsolo77 wrote:I always liked those TRD wheels and they look sharp on your Vibe. How does it ride with the springs ? Are they really bouncey ?
Thanks for the compliments. I am sure there are some knock off copies out there with your patterns.vibenvy wrote:Those TRD wheels look amazing ! I really like the simplicity of them! I just wish they fit our 2nd gen Vibe GTs .
You're very welcome !whitealltrac wrote:Thanks for the compliments. I am sure there are some knock off copies out there with your patterns.
Well this car is by no means a race car and these are lighter than the stock ones it replaced. I am very happy with them.thebarber wrote:I like the trd wheels, its too bad they're so heavy
Specifications:treesleavedents wrote:What's the offset on those TRD wheels?
I first tried the double defouler like is recommended, and got a different code since it could not detect any exhaust, so right now I have just a single one on mine. So far, it has been "good" for about a year now.whitealltrac wrote:Got the catalytic converter code will add a spacer the the O2 sensor once we get a break from the cold weather.....
