vibenvy's Mom's Garage - 2009 Steel Blue Metallic Vibe GT
Post by vibenvy » Sun Apr 29, 2012 12:46 pm
Build Date: 10.29.08 @ 8:23 am PDT -- 1 of 5 (0.053%) of 57,088 2009s built
Purchase Date: 05.23.09 (16 miles)
Color: Steel Blue Metallic (33U / WA602R)
Manufacturer Options:
• Electronically controlled 5-speed automatic transmission [with Driver Shift Control (DSC)] MVD
• Power sunroof [includes sunglasses holder] CF5
• Theft-deterrent alarm system [includes motion sensor, glass breakage sensor & fuel system shut-off] UA6
MILEstones:
• Turned over 10,000 miles - 03.18.10
• Turned over 20,000 miles - 01.25.11
• Turned over 30,000 miles - 03.22.12
• Turned over 40,000 miles - 05.19.13
• Turned over 50,000 miles - 05.24.14
• Turned over 60,000 miles - 07.27.15
• Turned over 70,000 miles - 09.20.16
• Turned over 80,000 miles - 04.04.18
• Turned over 90,000 miles - coming soon...
Links:
Flickr Photo Albums
MPG Tune
Modifications:
Engine:
• TRD radiator cap (#PTR04-00000-03)
• black painted exhaust manifold heat shield
• black painted engine oil dipstick handle
• Toyota engine appearance cover (#12601-0H020)
• TRD forged aluminum oil filler cap [with metallic silver painted insert] (#PTR35-00110)
• chrome engine appearance cover bolts
• K&N Typhoon short ram air intake [with AEM 2.5" to 3" rubber hump coupler (#5-574)] (#69-8613TS)
• AEM Dryflow air filter (#21-203DK)
• Optima 35 series Red Top battery (#8020-164)
• air intake ducting & resonator removed
• Magnaflow performance catback exhaust system [2.25" stainless steel mandrel bent piping, 5"×8"×14" satin stainless steel oval bodied muffler & 4" polished stainless steel round angle cut tip] (#16849)
Suspension:
• TRD front strut tower brace (#PTR02-12080)
• KYB Excel-G front struts (right/passenger side - #339194 | left/driver's side - #339195)
• KYB front strut mounts (#SM5638) | upper spring seats (#SM5763) | lower spring insulators (#SM5808) | strut boots & bump stops (#SB102)
• KYB Excel-G *AWD* rear struts (#340017)
• KYB rear strut mounts (#SM5382) | strut boots & bump stops (#SB132)
Wheels - Summer:
• 235/40/18 Hankook Ventus V12 evo ultra high performance summer tires
• Toyota [McGard] chrome OEM alloy wheel-specific wheel locks (#00276-00901)
• Slime chrome valve stem caps & sleeves (#20094)
Wheels - Winter:
• 2009-2010 Vibe 2.4L Base/AWD 16" steel wheels (#19184107)
• 2009-2010 Vibe 2.4L Base/AWD 16" wheel covers (#24100434)
• 195/60/16 Bridgestone Blizzak WS80 studless ice and snow tires
• 2003-2010 Vibe steel wheel/wheel cover-specific lug nuts (#88972746)
• Slime black anodized valve stem caps (#20266)
Brakes:
• PowerStop Evolution Performance drilled & slotted front & rear brake rotors [with satin black powder coated edges & hats] (front pair - #JBR1127XPR | rear pair - #JBR1363XPR)
• satin black powder coated front & rear brake calipers
• satin black powder coated front & rear brake caliper mounting brackets
• PowerStop Z17 Evolution Plus ceramic front & rear brake pads (front pair - #17-1211 | rear pair - #17-1212)
• Techna-Fit braided stainless steel front & rear brake line flex hoses [with a black PVC protective coating] (#TOY-2236)
Exterior:
• GM [Vosla] HIR2 +30% low beam headlight bulbs (#9012 = #9006 *with slight modification*) (#23342527)
• Philips HIR1 high beam headlight bulbs (#9011 = #9005 *with slight modification*)
• GM Accessories dark tinted hood deflector (#19158476)
• 2" round blind spot mirrors on the upper outer corners of the side mirrors
• WeatherTech dark tinted in-channel front & rear side window deflectors (#82481)
• 35% tinted front & rear windows
• Honda 7" antenna (#39151-STK-A01)
• metallic silver genvibe.com & Poyota decals on the lower right corner of the hatch glass
• SuperBrightLEDs warm white LED reverse light bulbs (#921)
PONTIAC VIBE GT badges removed from the hatch
• GM Accessories rear bumper cover protector (#19171162)
• SuperBrightLEDs warm white LED license plate light bulb (#194)
• Illinois Route 66 specialty vanity rear license plate - GDVBS
• eBay plain black plastic rear license plate frame
• stainless steel rear license plate screws [added two bottom screws]
Interior:
• Kool-Vue chrome front & rear door handles (right/passenger side front & rear - #REPT462119 | left/driver's side front & rear - #REPT462120)
• Grafx Werks regular red front & rear door lock overlays
• eBay black plastic front & rear door screw covers ×3 per door (listed for 2012+ Toyota Camry)
• eBay black plastic front & rear door check covers ×2 per door (listed for 2012+ Toyota Camry)
• eBay black plastic front & rear door striker covers (listed for 2012+ Toyota Camry)
• Auto Drive black leather steering wheel cover (#33124PW)
• Autobahn Kraftwerks [OBX Racing] stainless steel accelerator & brake pedal covers (#PTS22-33070)
• GM Accessories premium all weather rubber front & rear floor mats (#19170829) *discontinued*
• SuperBrightLEDs warm white LED reading light bulbs (#194)
• 2012-2014 Toyota Yaris chrome trimmed HVAC knobs (vent control [left/driver's side] - #55901-52400 | fan control [center] - #55902-52220 | temperature control {with rear defrost} [right/passenger side] - #55903-52650)
• SuperBrightLEDs amber LED HVAC knob light bulbs ×3 (#NEO4)
• GM Accessories chrome shift knob overlay (#19171212) *discontinued*
• 2010 Vibe metallic silver shifter bezel (#19205020)
• SuperBrightLEDs amber LED shift indicator light bulb (#74)
• SuperBrightLEDs warm white LED center & rear overhead light bulbs (#DE3175/30mm)
• GM Accessories rear cargo area security shade (#19171208)
• GM Accessories premium all weather rubber rear cargo area mats ×2 (#19170827)
Miscellaneous:
independent fog lights
Automatic Headlights (AHL) disabled
Daytime Running Lights (DRL) disabled
Tire Pressure Monitoring System (TPMS) disabled
OnStar module removed
• WeatherTech TechShade windshield sunshade (#TS0436)
• Diode Dynamics SmartTap CF18 LED flasher module [20 second departure lighting, 6-flash tap-to-pass & strobing hazard lights] (#LM449)
• K&N washable cabin air filter (#VF2000)
Future:
Suspension:
• Ultra Racing 2-point lower front brace [powder coated satin black] (#UR-LA2-2628)
• Ultra Racing 3-point lower front brace [powder coated satin black] (#UR-LA3-153)
• Ultra Racing 2-point lower rear brace [powder coated satin black] (#UR-RL2-583)
• Ultra Racing rear strut tower brace [powder coated satin black] (#UR-RE2-522)
Exterior:
• 5% tinted windshield strip [with black painted dot matrix]
Miscellaneous:
• Hella Super Tones dual horns [with black painted grilles] (#003399801)
• Redline Tuning QuickLift Plus hood lift system
Re: J_TO_ENVY's Mom's Garage - 2009 Steel Blue Metallic Vibe
Post by vibenvy » Sun Apr 29, 2012 1:11 pm
2010
Automatic Headlights (AHL) & Daytime Running Lights (DRL) Disabled + Independent Fog Lights - 03.05.10
"Birth Certificate" From NUMMI - 03.26.10
No More Winter Mode! - 03.29.10
06.13.10
Altgeld Hall @ Northern Illinois University - DeKalb, IL - 06.25.10
K&N Typhoon Short Ram Air Intake & AEM Brute Force Dryflow Air Filter - 07.02.10
GM Accessories Rear Cargo Area Security Shade - 09.24.10
09.26.10
09.27.10
10.22.10
Post by vibenvy » Sun Apr 29, 2012 1:35 pm
2011
Winter Wheels & Tires - 2003-2010 Vibe Steel Wheel/Wheel Cover-Specific Lug Nuts - 01.01.11
20,000 Miles! - 01.25.11
Honda 7" Antenna - 02.12.11
35% Tinted Front & Rear Windows - 02.21.11
Cat Vs. Vibe - 03.07.11
New Front Bumper Cover = No More Front License Plate Mount Holes! - 03.17.11
Black Painted Exhaust Manifold Heat Shield - 04.21.11
06.11.11
GM Accessories Chrome Shift Knob Overlay - 07.20.11
2010 Vibe Metallic Silver Shifter Bezel - 08.23.11
Winter Wheels & Tires - 2009-2010 Vibe 2.4L Base/AWD 16" Wheel Covers - 12.31.11
Post by vibenvy » Sun Apr 29, 2012 1:44 pm
2012
30,000 Miles! - 03.22.12
Toyota [McGard] Chrome OEM Alloy Wheel-Specific Wheel Locks - 03.24.12
Post by vibenvy » Sun May 06, 2012 3:42 pm
UPDATE
Optima 35 Series Red Top Battery - 05.06.12
Post by vibenvy » Tue May 15, 2012 4:22 pm
UPDATE
2nd GM Accessories Premium All Weather Rubber Cargo Area Mat To Protect The Backs Of The Rear Seats When Folded Down - 05.11.12
Post by vibenvy » Sat Oct 13, 2012 11:16 am
UPDATE
WeatherTech Dark Tinted In-Channel Front And Rear Side Window Deflectors - 10.11.12
Re: vibenvy's Mom's Garage - 2009 Steel Blue Metallic Vibe G
Post by vibenvy » Mon Oct 29, 2012 4:39 pm
4 years ago today, my mom's Vibe was "born" :D!
Post by vibenvy » Sun Nov 25, 2012 3:08 pm
Winter Mode 2012-2013 - 11.25.12
Post by vibenvy » Sat Dec 29, 2012 4:58 pm
I took this picture of my mom's Vibe a couple weeks ago in front of Altgeld Hall at Northern Illinois University in DeKalb, IL. This particular building has gargoyles on it and looks like a castle. To make it even cooler looking, there are Christmas lights, a wreath and orange lights shining on the building (because the Huskies are in the Orange Bowl this year!).
Post by vibenvy » Sat Feb 02, 2013 3:16 pm
removed
Post by vibenvy » Sun May 12, 2013 4:27 pm
UPDATE
TRD Forged Aluminum Oil Filler Cap [With Metallic Silver Painted Insert] - 05.12.13
A few other quick shots I took today since the Vibe was all nice and clean :cool:!
Infinity-x
Post by Infinity-x » Tue May 14, 2013 8:25 pm
Immaculate Vibe!! It's shocking that you can take such a close-up of the engine and not even see a spec of dust. Do the same with my engine and your camera will be covered in dirt LOL.
Post by vibenvy » Thu May 16, 2013 5:09 pm
Infinity-x wrote:Immaculate Vibe!! It's shocking that you can take such a close-up of the engine and not even see a spec of dust. Do the same with my engine and your camera will be covered in dirt LOL.
Thanks for the kind words :D! All I do is wipe the engine bay down with a damp towel after every wash.
Post by vibenvy » Sun May 19, 2013 4:15 pm
UPDATE
40,000 Miles! - 05.19.13
Post by vibenvy » Wed May 22, 2013 5:24 pm
removed
Post by vibenvy » Thu May 23, 2013 5:08 pm
UPDATE
TRD Front Strut Tower Brace - 05.23.13
Post by vibenvy » Tue Jul 23, 2013 4:15 pm
UPDATE
2013 GenVibe Meet Weekend - Pontiac, IL - 06.14.13 - 06.16.13
This is a pin with the Pontiac Route 66 mural on it that we received in our goody bags from the Pontiac / Oakland Automotive Museum and Pontiac Tourism Board. This just seemed like a neat place to put it.
Post by vibenvy » Sat May 24, 2014 3:13 pm
UPDATE
50,000 miles! - 05.24.14
Post by vibenvy » Sun Oct 26, 2014 4:43 pm
Took a little road trip to Lake Geneva, WI yesterday and just couldn't resist stopping to get a few shots of my mom's Vibe on Rustic Road...
Post by vibenvy » Wed Oct 29, 2014 4:18 pm
The Vibe was "born" 6 years ago today!
Post by vibenvy » Sun Nov 16, 2014 8:13 am
Last Saturday I spent the entire day detailing the exterior of my mom's Vibe in preparation for winter. I figured I'd get some pictures of it while it was all nice and clean. As you can see, I also switched to the winter wheels and tires.
Re: vibenvy's Mom's Garage - 2009 Steel Blue Metallic Vibe GT
Post by vibenvy » Sun Mar 22, 2015 12:27 pm
UPDATES
235/40/18 Hankook Ventus V12 evo Ultra High Performance Summer Tires - 03.21.15
Slime Chrome Valve Stem Sleeves - 03.21.15
csxt8058
Post by csxt8058 » Sat Apr 18, 2015 1:43 pm
New tires for spring time, looks good!
JR
Post by vibenvy » Sun Apr 19, 2015 1:06 pm
Yes. They have been amazing so far! So glad I got them!
UPDATES
Stainless Steel Rear License Plate Screws [Added Two Bottom Screws] - 04.12.15
Chrome Engine Appearance Cover Bolts - 04.18.15
$1.59 a piece at my local Ace Hardware. Adds a nice little touch to the engine bay.
Post by vibenvy » Wed Aug 12, 2015 2:01 pm
UPDATE
60,000 Miles! - 07.27.15
Post by vibenvy » Sat Sep 19, 2015 10:09 am
UPDATES
eBay Plain Black Plastic Rear License Plate Frame - 09.11.15
Black Painted Engine Oil Dipstick Handle - 09.13.15
Post by vibenvy » Sun Nov 01, 2015 12:49 pm
UPDATES
All Nice And Clean :cool: - 10.17.15
2012-2014 Toyota Yaris Chrome Trimmed HVAC Knobs - 10.31.15
And on a bit of a side note, my mom's Vibe turned 7 last Thursday, October 29th!
Post by vibenvy » Sat Jan 16, 2016 9:00 am
UPDATES
eBay Black Plastic Front And Rear Door Hinge & Striker Covers - 01.06.16
TRD Radiator Cap - 01.06.16
Illinois Route 66 Specialty Vanity Rear License Plate - GDVBS - 01.08.16
Post by vibenvy » Fri Feb 26, 2016 2:51 pm
I took full advantage of the beautiful weather last weekend and washed both Vibes and my dad's Trax. I snapped this quick picture of the rear end of my mom's Vibe to better show the new rear license plate...
Post by vibenvy » Wed Sep 21, 2016 3:33 pm
UPDATE
70,000 Miles! - 09.20.16
Post by vibenvy » Sat Oct 29, 2016 4:35 am
Today is my mom's Vibe's 8th birthday! Still looks and feels like a brand new vehicle at just over 70,000 miles!
Post by vibenvy » Sun Jan 15, 2017 7:27 am
UPDATES
Kool-Vue Chrome Front & Rear Door Handles & Grafx Werks Regular Red Front & Rear Door Lock Overlays - 01.15.17
Post by vibenvy » Fri Apr 06, 2018 6:03 pm
UPDATE
80,000 Miles! - 04.04.18
Post by vibenvy » Tue Jan 29, 2019 3:28 pm
I can't believe I forgot to post about GDVBS turning 10 years old back on October 29th!
