Hey all. I'm new to this site (and car stuff in general). I decided to tackle installing a new head unit which went smoothly, but it came with a microphone to install on the driver side visor. At the moment (temporary fix, I hope) I used some 3M strips to keep the cable in place and I ran it down the A-pillar trim and down around the dash by the door and above the steering column into the unit.
What I would like to do, is run the cable under the A-pillar trim and under the dash to the unit, however I'm not entirely sure
a) if this is the best way to run the cable
b) how to remove the A-pillar trim to run the cable underneath
c) if there is anything I should be aware while trying this (would the air bag be an issue? other pitfalls?)
This may be more suited to electronics, but since the installation of the unit is done, I figured this forum might be a more appropriate place to ask. Thanks!
