WhgVibe wrote:Flip Side, There is a 04 Vibe GT for sale down the street from my work place. Dark ( Brick) Red. Has 99K miles. I think they are asking $5500. If you are interested I will get you their number. Car is in Moundsville WV, about 15 min south of Wheeling WV.
How about 142k for $4200?Nasmfell wrote:WhgVibe wrote:Flip Side, There is a 04 Vibe GT for sale down the street from my work place. Dark ( Brick) Red. Has 99K miles. I think they are asking $5500. If you are interested I will get you their number. Car is in Moundsville WV, about 15 min south of Wheeling WV.
That's too much.
KITT222 wrote:How about 142k for $4200?Nasmfell wrote:WhgVibe wrote:Flip Side, There is a 04 Vibe GT for sale down the street from my work place. Dark ( Brick) Red. Has 99K miles. I think they are asking $5500. If you are interested I will get you their number. Car is in Moundsville WV, about 15 min south of Wheeling WV.
That's too much.
Thanks all, good to be back!lannvouivre wrote:Excellent, Flip-Side! The thing that makes me the happiest about these cars is how freaking easy they are to work on. Like, every day I have to work on something with a difficult design, I feel completely smitten by my car again.
Flip-Side wrote:Thanks all, good to be back!lannvouivre wrote:Excellent, Flip-Side! The thing that makes me the happiest about these cars is how freaking easy they are to work on. Like, every day I have to work on something with a difficult design, I feel completely smitten by my car again.
You are very right Lannvouire. It is one of the main reasons I keep going back to this vehicle. I only have a few items of note for the early models I personally owned:
-The non-standard sized cast hex nut used on the belt tensioner - Nothing fits perfect and you can break it off if you are not careful
-Burping air bubbles from the coolant system. Fill, rev, burp, fill, rev, burp, fill, drive like a mad man to increase coolant flow, burp again.
-GT/XRS models break lift bolts after a while, so you should change them out before they do. If they break, usually just lose lift.
-The C56 and C60 final drive and some gears are weak and syncros start to grind if you are not careful, or do not change gear oil regularly. The autos are pretty tough if you take care of them.
-The dang gas door hinge on the pontiac only.
-All the VSVs tend to go bad and clickity clack. Usually do not cause issues, but a pain to track down when they do.
-The fan speeds always go out on me, but the part isn't too bad to replace.
-The A/C clutches tend to fail/fall off, also a fairly cheap fix since the compressors rarely die.
-Drivers window always had issues until the recall for the rivets.
-Had 1 airbag module paid to replace prior to the recall.
-The oil pump is weak, mis-shifting can blow it apart and the engine is pretty sensitive to oil level.
-Different tire type in front and back handle awful. Pretty much all econo-tires handle/wear poorly for me.
-The exhaust donut tends to leak/make noise over time, and most big chain autopart stores have the wrong part# in their system for the Vibe/Matrix. Cheap fix though.
I digress. I honestly have so many miles on this platform, I can't believe how reliable they are. I've had many vehicles in between. Tiburon, riviera, soul, subarus, caravan, etc, and they all came and went from reliability issues.
Long winded I know but don't forget, much of my experience was originally gained from this very forum and it's members. Thanks again!
The 2ZZ-GE engines will be the one with oil pump issues, right? Haven't heard of the 1ZZ oil pump having issues.Flip-Side wrote:2003 Vibe/Matrix were what I owned.
2003 Base Vibe w/Automatic
2003 Matrix XRS w/6-speed
2003 Vibe GT w/6-speed
Many of the items I mentioned are the same through 2003-2008 I would think, though I am not positive since you can see the model years I have owned. I stuck with 2003 because they were always cheap, and the GT/XRS was the fastest in that model year due to the higher rpm red-line and lower rpm lift engagement than later models.
Mine just has low compression, it doesn't consume oil yet. My numbers are 155 psi, 180, 180, and 150 psi without oil added from the top to help the rings seal. Lowest acceptable number is 145 psi, highest is 210, acceptable range is 12 or so psi. For me, it's just power and fuel economy being gutted.Flip-Side wrote:The oil issues due to ring wear was never witnessed by myself, and my ex-wife was absolutely awful to that poor base vibe. It really was a champ, and never lost any appreciable amount of oil. I have hear of issues from other owners on occasion, though I have always viewed the base 1.8L as a very reliable motor.
