You can always check the code against the sticker in the driver's door. Doing a quick google brought up several sites that all called it a different name (black mica, black pearl metallic...) but had the same color code.lowincash wrote:Just curious, I thought the 09 black is called Jet Black Metallic. When I searched the code 19U/WA546G it shows it's Black Mica. Think it'll match?
Agreed. None of the 2009 color names listed above match the actual color names, but as Rayven said, as long as the paint code is the same, it will match.Rayven01 wrote:You can always check the code against the sticker in the driver's door. Doing a quick google brought up several sites that all called it a different name (black mica, black pearl metallic...) but had the same color code.lowincash wrote:Just curious, I thought the 09 black is called Jet Black Metallic. When I searched the code 19U/WA546G it shows it's Black Mica. Think it'll match?
The color didn't change in your model year, so the 2003 code is correct.Plarka wrote:Why does the color for my 2005 come up under the 2003's? I looked up the WA number in the glove compartment. It's blue.
Check the inside of the govebox door. You should see a sticker with a bunch of letters and numbers on it. These are RPO codes. You will also find the paint code on this sticker. It's going to be either 22U or 82U.MaxxVibe wrote:no where listed do I see a paint code for 2009 Mystic Blue Metallic. anybody?
vibenvy wrote:Check the inside of the govebox door. You should see a sticker with a bunch of letters and numbers on it. These are RPO codes. You will also find the paint code on this sticker. It's going to be either 22U or 82U.MaxxVibe wrote:no where listed do I see a paint code for 2009 Mystic Blue Metallic. anybody?
The white color is called Frosty. You will need the correct paint code for finding the proper paint, see the paint codes in the first post. You can also find the paint codes on the service parts identification label inside the glove compartment.Ugetmyvibe wrote:I have a 2003 base. Can anyone decided the manufacturer paint lingo and spell it out plai9nly? Mine is white.
