Rear Brake Squeak - Car Off In Park
Postby viberu » Sun Jun 10, 2012 10:57 am
2003 Vibe. Without turning the car on and the car is in park - if you press the brake pedal there is a squeak coming from the rear wheels. What is the most likely cause of this type of squeak? Is the solution simply to grease some mechanical brake part? Thanks!
viberu
Re: Rear Brake Squeak - Car Off In Park
Postby bluneon » Sun Jun 10, 2012 12:37 pm
your rear brake shoes are rubbing on the drum backing plate. re-lubricating the contact points of the shoes to the backing plate will eliminate this.
bluneon
Postby viberu » Sun Jun 10, 2012 2:05 pm
Ah, so even when the wheel is not moving the shoe to drum backing plate interface can still squeak?
viberu
Postby trb » Sun Jun 10, 2012 6:06 pm
I've been meaning to look at my son's rear drum brakes. His squeak right when you let up off the brakes. Just haven't had the time.
1987 5.0 LX bought new 3/31/87. 306,000+ mile former daily driver
2010 Red Vibe GT - my new daily
2013 Equinox LTZ - wife's daily
Postby bluneon » Sun Jun 10, 2012 6:27 pm
viberu wrote:Ah, so even when the wheel is not moving the shoe to drum backing plate interface can still squeak?
yes, these parts still move even when not moving.
bluneon
Postby viberu » Sat Jun 16, 2012 11:59 am
Is it possible to just remove the wheel in order to lubricate these points? Or, must I remove the springs and shoes? Thanks.
viberu
Postby bluneon » Sat Jun 16, 2012 4:21 pm
you'll need to remove the drum. it's up to you if you want to remove the retaining washers and springs holding the shoes to the plate. i remove the washer and springs so i can get better clearance to re-lube the contact points and not smear any grease on the shoe lining. some people get away w only using a screwdriver to lift the shoe away to re-grease.
while you're at it you may as well adjust the clearance between the shoes and drums, this way you'll have a more responsive braking.
bluneon
Postby Water boy » Sat Jun 16, 2012 6:56 pm
I thought the rear drums were auto-adjust?
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
Water boy
Postby bluneon » Sat Jun 16, 2012 10:37 pm
they are, but but only minimally. when the shoe clearances are too far out but too close to self adjust then the brake pedal will be mushy, taking the car a longer distance to stop....similar to air in the brake lines, that kind of soft pedal feel.
readjusting the shoe clearances will improve brake feel and response.
when the shoe clearances are too far away from the drum the hydraulic system will need to compensate for these clearances until the shoes start to grab. the wheel cylinders use up most of the hydraulic pressure from the master cylinder while the pedal is pressed to push the shoes closer to the drum....once the cylinders take up whatever pressure/fluid it needs, the residual pressure is then transferred to the front calipers.
if the shoes are adjusted closer to the drum then the cylinders won't need as much fluid pressure. if the rear cylinders take up very little pressure to move the shoes then the rest of the pressure will transfer to the front calipers faster and the pedal will be firmer and the car will stop quicker.
bluneon
Postby knightrace » Sun Jun 17, 2012 8:49 pm
My 05 squeaks like that as well. I haven't made the time to look at it. Would like to have someone apply the brakes with the drum off to see where it's coming from.
2005 Frosty White, Moon & Tunes, Leather, Auto
Disabled DRL & AHL
Double Compartment Armrest
Hella Super Tone Horns
knightrace
Return to Problems & Warranty Issues
Who is online
Users browsing this forum: No registered users and 0 guests
x
