The rear passenger side drainage tube in my car behind the cladding in the cargo area was kinked, which was causing leaking (
http://forums.genvibe.com/zerothread?id=25645). I know you said you blasted air through the drainage holes (so did I), but did you look under the car to make sure the water was actually draining from the tubes? If they are all draining properly there will be four wet spots (on the road) where they empty, kinda near each corner of the car.Also, I believe you should be able to adjust the height of the moon roof glass itself, might be able to get a better seal that way.
