Nikkib80 wrote: ↑Tue Nov 01, 2022 2:33 pm
Having taillight plate light issues is not the obvious fuse relay connector nor out let so I think it may be the switch or I know it's an open circuit I have to find the exact info I need good ground to circuit diagram idk Chilton Keeps referring to the Haynes Manuel I have no money for so any ideas where a free workshop on 05 is
Are you having problems with just the license plate light, or with that and the tail lights too?
There is a TAIL relay in a fuse block located above the glove compartment. Some here have had that relay either go bad, or just work itself loose. You can probably check if its loose by reaching up and around, but for reference, a picture of what it looks like on top when its been unbolted and hanging down is at
download/file.php?id=4970
The three same size are all the same relays, so if you suspect the tail light relay is bad, try swapping it with the 110V inverter one
If that's not it, then check out the attached excerpt from an 03 Toyota Matrix manual, should be the same for your 05 Vibe, maybe that will help troubleshoot
