I see on the ScanGauge website that with the latest software one has access to the XGauge features i.e.http://www.scangauge.com/support/xgauge.shtmlFor those of you with this software can you tell me if your ScanGauge II is able to display the oil temperature in degrees F and oil pressure in PSI?Thanks for checking.
Google is your friend.I've found much on some forums that I would have never found on my own where people have played around with the programing to get various readings.I've had 2 SG for 2+ years. Played a little with the programing on the Vibe when I first got it but never revisited. On my list to due before I die.
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
...the ScanGauge-II can only display what information the computer passes along, and then only if the engine has the senor(s) to collect that information in the first place.
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
Quote, originally posted by Water boy »Google is your friend.Of course but I am interested in the oil pressure and oil temperature for a Vibe. And as this is the forum for all things Vibe I thought it might be likely that someone here has used XGauge successfully in this regard.
Quote, originally posted by Old Tele man »...the ScanGauge-II can only display what information the computer passes along, and then only if the engine has the senor(s) to collect that information in the first place.I understand. So I am wondering if any Vibe owners have been able to display oil temp and oil pressure using the XGauge software.
