Hello all, The GenVibe.Com Registry
http://www.genvibe.com/cgi/registry/registry.cgi has been updated to use the same login as your forum account.If you don't have a forum account already, you will need to create one before you can update your registry again.When logging into the registry, use your forum username and password. The first time through, you will get an extra form that allows you to link your forum account and registry account by entering in your forum username, forum password, old registry username, and old registry password. After you've done this, you can access your registry using your forum username and password, and you will not need your old registry username or password any more. Also, a link to your registry will be shown under your name in any posts you make on the forums.If you have any problems with the linking process, post them here and I'll try to assist.
