Brake problems with 2009 Vibes?
Houston
Post by Houston »
A dealer tech told me that the brake pads on 2009 Vibes have more metal content then previous ones and are subject to making brake noise. How many of you with 2009 Vibes have complaints of any kind regarding the brakes on your 2009 Vibe? Anybody?Thanks!
goochsmooch
Re: Brake problems with 2009 Vibes? (Houston)
Post by goochsmooch »
I totally notice a squeal in the brakes when I come to slow stops. I should probably get it in to the dealership before it closes down. Is this something they would cover under warranty, or do they just state it as a fact of life with these cars? If so, (removed)!?
2009 1.8L Vibe - Manual
Houston
Re: Brake problems with 2009 Vibes? (goochsmooch)
Post by Houston »
Quote, originally posted by goochsmooch »I totally notice a squeal in the brakes when I come to slow stops. I should probably get it in to the dealership before it closes down. Is this something they would cover under warranty, or do they just state it as a fact of life with these cars? If so, (removed)!?Is your noise sort of like a whistling noise that sometimes lasts a few seconds even after you've removed your foot from the brake pedal? If so, this doesn't sound like any brake noise I've ever heard.I would think this problem would be covered by warranty. I don't know about you, but I have only 372 miles on mine and there's no way I'm going to spend the entire life of this car listening to that blasted noise.I'm hoping all 2009 Vibe owners chime in here, even those without problems, just so I can get an idea of how common this is.
jake75
Post by jake75 »
I never noticed - but then I am a little hard of hearing.
PMC
Post by PMC »
I have heard a little bit of a faint squeel sometimes after I start the car and back out of the driveway. When I drive the first 100 meters or so I hear the sound even without the breaks on but then it seems to go away after I drive for more then 2 or 3 minutes. It doesn't seem to be every time. I have about 3,000km on my Vibe.
Sublimewind
Post by Sublimewind »
I bet most of these problems could be remedied with some "brake quiet" applied to the back of the pads.. The pads are likely ceramic or metallic, and they usually always make more noise.. Part of the ills of removing asbestos, which was perfect for the job...
vintagegz
Post by vintagegz »
The new vibes have 4 wheel discs as opposed to the rear drums on the previous generation ( except for the GT's) so more squeel is probably expected. Remember to service the calipers once a year or so, especially the rears.
Houston
Re: (Sublimewind)
Post by Houston »
I sent an email to a couple people at my dealership last night telling them I was going to bring my car to them today, that I wanted a loaner, and for them to keep my car as long as it takes for them to hear the noise, locate the problem, repair it and call me when it was ready to go. They just called and said they have a loaner ready. I'll let you know how all this turns out and what the problem turns out to be.
Silversn95
Post by Silversn95 »
no brake issues or noise here with about 8000km.
2009 Pontiac Vibe - 1.8L 5-speed 1SB Carbon Gray Metallic with 20% tint
No noise here. But I know that (on the Sunfire) when it's cold out or it's been raining, the front brakes have a tendency to make a dull, high pitched grinding sound. The brakes themselves are fine (original brakes 40% left) and once they're warmed up it goes away. It only happens though when it's cold and/or damp. It's been hot and dry here lately so I have yet to see if the Vibe does this. But you can hear the engine rev as a high pitched whisle through the stereo when the aux jack is in use (I have my sirius hooked up through it) but only on certain channels and only when the volume is really low.
2019 Ram 3500 4x4 CCSB srw 8HP75
safooma
Post by safooma »
13k(miles) on my 09 and i havent noticed this...although i have a pretty loud stereo ;-)
Silver 2009 Base 1.8 5spdMPG info for my vibe: http://www.cleanmpg.com/index....=2758
Kincaid
Post by Kincaid »
I haven't noticed any brake noise.
kowell
Post by kowell »
No noise or brake issue after 22,000km on my 09
2009 Vibe 2.4L 1SC - Red Hot Metallic
2011 Sienna V6 CE - Sky Silver
Kaotik3
Post by Kaotik3 »
I have a 09 Vibe GT and I am currently hearing a grinding (metal on metal) noise when I brake hard. Sometimes it continues when I let off the brakes and start to accelerate, and eventually stops. My boyfriend looked at the brake pads and they look fine and the rotors do not have any grooves. Any suggestions?
09vGT
Post by 09vGT »
I have grinding noise as well. I've always noticed it.
