It depends on what the spoiler looks like. If the spoiler is a small lip, then it's theoretically possible that it's there to (get this) improve aerodynamic drag. A spoiler (note that this is different from a wing) will separate the airflow from the car from that point back (hence the name, as it "spoils" the laminar flow). If it is properly placed, it can prevent unstable airflows that attach and detach, or simply choose an advantageous separation point that reduces overall drag or lift. MOST of the time when you see a spoiler on a car it is just to make it look cool and no engineering has been done on it whatsoever. Rarely is a road car designed to produce downforce. If they are engineered, spoilers are usually being added to reduce lift (squint your eyes enough and the general car profile is that of an inverted wing). Porsche put features on the 911 to separate airflow so that the rear profile of the car wouldn't produce enormous amounts of lift. Audi apparently recalled the TT because aerodynamics and suspension settings caused the car to become unstable at Autobahn speeds:
http://www.fantasycars.com/Audi_TT/audi_tt.htmlBy contrast, I have read that the spoiler on late-model Mustangs not only increased drag, but actually produced lift as well.These aerodynamics do come into play at any speed, and go up with the square of it, so spoilers are doing SOMETHING out there, but as I say, usually it's not anything particularly well planned out.
