AWD REAR SUBFRAME
shermaner12
AWD REAR SUBFRAME
Post by shermaner12 »
Hey everyone I am looking for any one that has an AWD 03-08 Vibe they are parting out that still has the rear subframe/differential carrier. i found a pretty sizable hole in mine when i crawled under to fix some of the heat shields.
Also if anyone has a blend door actuator
and even a decent AWD exhaust would be helpful too
Also if anyone knows any of the interchanges that uses the same rear subframe. I've read the celica?.
Re: AWD REAR SUBFRAME
The following vehicles use the same rear subframe:
03-08 AWD Matrix/Vibe
99-06 Celica GTS (must be GTS as that had the IRS)
09-10 AWD or GT/XRS Vibe/Matrix
Matrix was continued until 2013, I presume the rear subframe remained the same, but have no confirmation. I'm not sure if the AWD or XRS trims were carried through those years.
I have no idea if the rear diff is the same, though I'd venture to guess it's very similar as I know the rear axles are the exact same.
