Still keeping an eye out for ya!KnightmareCS wrote:Reposting this if you come across anything in the yard:
Any of these? For an 05 base FWD.
-Pass side outer rocker panel, non-extended, preferably in abyss.
-Front lower grill ducts.
-Front window switch panel, driver side, with no broken tabs? Don't need the actual switches, just the trim panels.
-Driver side fog light
-Complete roof rail crossbars
I can see about the cup holder, as far as the center console, I'm afraid shipping will be too much, but I will check.M1MECHANIC wrote:Was wondering if you have a center console or just the cup holder in the back for sale
Thanks!NYfan08 wrote:Still keeping an eye out for ya!KnightmareCS wrote:Reposting this if you come across anything in the yard:
Really just need the cup holder wasn't sure if you would be able to pull it out. My console is just fine only need to replace the rear seat cup holder in it.NYfan08 wrote:I can see about the cup holder, as far as the center console, I'm afraid shipping will be too much, but I will check.M1MECHANIC wrote:Was wondering if you have a center console or just the cup holder in the back for sale
PM'd for tracking number if you've got it...NYfan08 wrote:Pm replied, Duraflex caps sold! Thanks!
Kitt222 wrote: "Remove the cubby, and you'll find a little metal tab in the top of the hole. Bend it towards the driver, and it holds the cubby closed a LOT better."BustedVibe wrote:Will those Door Trim (sail panels?) fit on an 04 Vibe?
I could maybe use those in place of messing up my tweeter covers.
Also if you are still able to look for parts, I might be interested in acquiring the door/compartment for the center shifter console for a fair price. The latching tabs on mine came worn out with the car and the damn thing never stays closed. Replacement is like $35!
Aww man, sold the only trailer hitch I found not too long ago. No luck on the bumper inserts either, most are gone/missing or the front of the car is trashed. Sorry. But I am always keeping my eye out for those types of things.KRR wrote:NYFan - Two thangs:
Trailer hitch (w or w/out pull bar)?
and
Front left small bumper insert thingamajiggie.
If you run across these, I'm in the market.
I have a set, one is damaged though. I would do $25 + shipping for the good 3.Petrus wrote:Looking for wheel covers for 06 vibe. Thanks
Not sure what you are referring to...for the luggage rack? I can see if there are any left at the yard that dont have the retaining clip broken.opsmanager1218 wrote:I need drivers side end caps front and back,,interested in selling thse to me?thanks
Had some, sold them already. None at the yard. Sorry.knewman25 wrote:Hi - I am looking for 16" wheel covers for my 2004 Vibe. Looking for bare minimum of one to replace the one that broke, but would love 4 in good condition. Thanks!
Thanks! I'm tired of having a broken door handle and radio bezel (I found out what it's called after I posted my request). Have a great weekendNYfan08 wrote:I can check for the radio trim when i go to the yard monday. Door handle is no problem. Mats are a no go, most are gone or have been exposed to the elements. I will message you back on monday around 5pm with what I find and a cost. Thanks
In that case, I'd have to find where the two wires around the steering column are, or take the center console apart and splice in where the original button connects. The stripped, bare wires in the shifter shaft are still there, just taped off with electrical tape to keep them from contacting each other.NYfan08 wrote:I can get one. What I did is exactly what your 2nd option is. I mounted mine in one of the dash blanks, ran the wires up through the dash. Easy fix. I used the tire switch that came in the tpms system. I have another switch if you wanna go that way. Either way, I can get what you need. I will also get a pic of my switch.
