you can get then from a junk yard. look for pontiacs like the sunfire and such they use the same ones to hold the hub caps on also. this is a way that wont cast much if any money. you may even be able to find the pontiac plastic caps that go in them also. i use to have a sunfire with the same setup to hold hub cap on and the plastic caps for cosmetics. hope this helps.
