I have a C60 from a celica modified to fit a corolla, matrix, vibe or spyder shifter
my trans works fine but has slight grinds mostly when cold but doesn't pop out just doesn't like to be rushed
you still need 1 or 2x parts from monkey wrench racing for the shifter conversion shaft and the reverse blockout if you fancy not going into reverse at 30 mph
basically the spyder shifts from the front of the shift shaft and has a 2 bolt bracket for the shifter arm to the right
the celica trans shifts from the rear and the shaft has to be knocked out and the hole in the back needs to be closed off with a freeze out plug (which i did)
the advantage is that the celica shift cable brackets bolt to the same spot as the spyder shifter arm (on the corolla vibe and matrix there is a blank undrilled boss on this spot, on my spyder swap i used a vibe trans and drilled and tapped these two holes)
aside from a spare stock shifter you could maybe cut shorter and a 6 speed trd ball knob i sold everything shift related
03 Vibe GT JDM MR-S 1ZZ-FED swapped w/C60 6 speed - Starting Part out! - 230k mi
90 Celica Alltrac Awd Turbo ST205 swap Red - sold... Buy more parts BC I'm Buying her back!
01 MR2 Spyder Vibe 2ZZ-GE w/ Jdm C65 LSD Trans swap -sold
You didn't scrap it yet, did you? Also, I want those headlights, front bumper, and rear roof rack cap(p/s) if you have it.
I lost my roof rack hardware, do you have any of it by chance?
I might have a use for that c60. Mine sounds like it's about to go, I don't think it will like 300hp much. I'm hoping I can make it last until the e154f goes in,
but that is unlikely.
OK I sorted through my trim, I do have a complete p/s in black
I have pending sale on d/s blue and p/s black front door cladding
I have an additional p/s front door cladding in black
Also black:
2x p/s rear door
1x p/s rear qtr
2x d/s rear qtr (1x in unpainted grey)
1x d/s front fender (scuffed w/ one broken clip)
1xp/s front fender
And also 1x d/s+p/s front fender cladding in unpainted grey
Thank you for your quick response, but these pieces I have; I need the bottom section where the rocker is, all across the bottom. about that, not making myself clear. I hope you have that. Thank you again.
That I definitely have, sorry for making everyone wait on pics my parts are in detached garage beyond a muddy field of melting snow and a not hard to get to and school work gym keeps getting in way off Thurs will get back to everyone then
Fogs sold, here's pics - also while im sure i have a battery tie down i have no idea where it may be and could not find it after 1/2 hr of digging so....
ghetto looking but functional radio
abs unit
Did you say you had side skirts? I have a 2004 Vibe base and wanted to see if I could put those on. The part number may be part of the
12498773 Sport Package
Do you still have that black rear spoiler and does it fit a 2003 vibe? I'm interested if it does and thanks for checking on the skirts, I have all those that you have, I need the bottom one, one whole piece that runs at the bottom passenger side.
When you say basic side skirt are you referring to the lower one? Can you post a picture, I'm interested in the spoiler and the skirt, how much and shipping charges for 14622 zip.
Did you sell the driver's side rear tail light/blinker assembly? You mentioned that you have a cracked one (picture shown) but also maybe a good one? Can you send me a private message if you still have them with costs to ship to 97202? Thanks.
