2006 Pontiac Vibe fwd
Links to other useful Pontiac Vibe & Toyota Matrix (and related) websites.
fixitfelix2018
Post by fixitfelix2018 » Thu Jan 03, 2019 6:36 pm
I am in need of a anti roll sway bar kit complete with brackets and bushings. Even a performance kit will do any body please help.
Bookworm
Re: 2006 Pontiac Vibe fwd
Post by Bookworm » Thu Jan 03, 2019 7:09 pm
You mean something like the MOOG front end kit?
https://www.rockauto.com/en/catalog/pon ... +kit,15413
Or do you need the sway bar link and bushings, which is called the stabilizer bar by RockAuto.
https://www.rockauto.com/en/catalog/pon ... suspension (The bushings and bar are separate).
SeattleJeremy
Post by SeattleJeremy » Tue Jan 15, 2019 12:03 pm
Bookworm nailed it. If your car needs end links or bushing check out rockauto. If your car doesn't have a sway bar at all check out wrecking yards. Any FWD 03-08 Vibe or Matrix front sway bar will work. They should all be the same diameter.
The AWD cars have thinner front sway bars.
To install the front sway bar check out this thread, and the two threads linked there.
viewtopic.php?f=28&t=44362&p=505343
06 Vibe Base - Mono Platinum - Manual
