Takata airbag replacement electrical problems afterwards.
Posted: Wed Nov 21, 2018 6:39 am
I recently had the Takata Passenger airbag replaced on my 2009 Vibe 2.4 Base and now the horn does not work - coincidence? I used the horn (deer in road) on the way to the GM Dealer so I know it worked that morning. I checked the fuse - good. I connected the horn directly to the batterly - it beeped. I replaced the horn relay, horn still does not work. I even removed the driver side airbag (after disconnecting the battery) and checked the horn ground - it was connected. QUESTION? has anyone else had electrical problems after the Takata airbag was replaced??? The dealer wants $242 to fix the horn.
