Gen 3 Vibe?; Kia's 50mpg Nero Hybrid.
Posted: Sat Feb 27, 2016 12:39 pm
by Chiadog
Kia's new Niro Hybrid appears to be a near perfect VIBE Clone!
http://www.automoblog.net/2016/02/24/fi ... ro-hybrid/
Re: Gen 3 Vibe?; Kia's 50mpg Nero Hybrid.
Posted: Fri Mar 04, 2016 12:22 pm
by Chiadog
Kia Nero has some pretty impressive technical specifications. Significantly, it does not have a 12 Volt car battery! I've always wondered why a hybrid needed an "extra" battery.
http://www.greencarcongress.com/2016/02 ... 2-kia.html
Posted: Sun Mar 06, 2016 9:50 am
by BenWA
The "extra" battery is a good idea in a hybrid IMO, with it comes to the likes of the Prius. (Something baout how the hybrid system is different from the likes of Ford's I recall reading)
If you are far from home and your hybrid bank goes to crap from a bad cell or two without warning, you can still start and drive it as a regular gas car with a starting battery and the gas engine.
Posted: Sun Mar 06, 2016 4:32 pm
by Chiadog
Anything is possible, but if I'm not mistaken that "Safety" battery let a lot of ford hybrid drivers down!
Posted: Sun Mar 06, 2016 7:14 pm
by BenWA
That's what I meant. The Toyota system gives you a more of a fail safe backup way to drive if the hybrid system fails in one way or another. Ford's doesn't. And maybe Chevy's too? It's been a while since I read about it. I had considered a used Prius when I was considering cars; but I ultimately decided on the Matrix/Vibe.
As I recall, the Ford gas engine on a hybrid relies on the hybrid bank to start.
Posted: Mon Mar 07, 2016 6:54 pm
by Chiadog
From memory, I think Ford and Toyota both use the planetary gear hybrid drive system, very complex but also the most efficient system. Both use a 12 volt car battery to start the engine.
The Kia Niro uses a much simpler hybrid system which is technically less efficient in operation, but offsets the efficiency deficit with a larger lithium ion battery, allowing for more miles driven before the engine is forced to run. The Niro system has only one motor/generator which is sandwiched between the engine and the automatic transmission. It'll be interesting to see how close they get to 50mpg!
Posted: Mon Mar 14, 2016 6:28 pm
by BenWA
I might be wrong on who is like Toyota and who isn't....
Posted: Sat Mar 11, 2017 8:26 pm
by JPark
I was just checking the Niro out. Its interior dimensions are near identical to the First Gen Vibe. Nice! I'm interested in the plug-in hybrid due at the end of the year. One issue: it looks like the seats don't quite fold flat.
Posted: Tue Mar 14, 2017 3:36 am
by lannvouivre
The 12v normal car battery closes the high voltage electrical contacts on the high voltage hybrid battery system, at least in Fords. That's all it is for.
Posted: Tue Mar 14, 2017 7:43 am
by petervivian
Looks nice. What about the quality of Kia's recent small cars?
