I have an 05 maxx and it's a very decent car. Gets about 27 MPG compared to my vibes' 34. Cargo space is nearly identical, 6' boards will fit with the back seats folded down flat. The front passenger seat back even folds flat like the 1st gen vibes. The middle seats are on rails which is nice for leg room. Rear disk brakes are standard.
Only problems I've had are with wheel bearings, vanity mirrors that snap easily, bad clock spring. There's a common problem with the headlights where the DRL bulb will burn through the housing and cloud up the lamp. Also the stock rotors / pads were low quality and had to be replaced on all 4 corners by 50K miles. Everything was easily and cheaply repaired by myself.
The only FWD car GM has made worth owning imho, is the GEO, Vibe and maybe a few Saturns all because of Toyota. The Maxx is interesting but has stupid little issues that shouldn't go wrong, as stated above. I was a GM man up to the mid 70s then they produced junk. I'll tell you a story about my buddies 05 Chevy Colorado, you can't pull the front rotors off with out a $$$ special tool. Even the dealer turns them on the truck. FAIL!!!
As a former 2004 Malibu Maxx owner, I was interested in reading what GM finally decided to do about the myriad of problems surrounding that car. This latest recall campaign seems to be a joke. Regarding the Maxx, GM is going to do a simple fix on the wiring harness to prevent corrosion and thus, prevent brake light failure. Really? I was thinking GM should maybe recall the car due to dirty driver's side windows and have people bring their car in for some Windex and a wipe!! What really needs to be corrected in those cars is the steering column and steering gear which repeatedly failed on those cars. GM may have done me a great favor by ruining my car (unnecessary axle seal replacement) and forcing me to get rid of it after a near death accident. In 2002-3, GM spent over a billion dollars retooling the Malibu Maxx plant in Kansas. After doing all the research, I bought one new back in 2003 and loved the car. While ugly, I feel it was the most versatile car on the road at that time. Had a repair job not been dangerously botched, I'd be in my 10th year of ownership. The Maxx is hard to find on the road only after 10 years. I surmise that most have been crushed for scrap metal. The Vibe aside, which is a Toyota, I will never own a GM product again after owning the Maxx and seeing how lives were put at stake by a company who chose not to correct numerous, well documented, serious issues with failed steering components.
you are always welcome Chia. What I am waiting to sit and drive is the upcoming Honda HR-V, slightly smaller than the CR-V. Should be out by the end of the year.
