Can someone remove their gas cap and tell me if the opening of the filler tube has a flap that covers the hole at the top. Every car I've ever owned with has a small flap that gets pushed out of the way by the pump nozzle. The flap is to prevent gas from splashing out. My Vibe doesn't have one. I wonder if it's not supposed to or if it's fallen off and down into the tank.
Car: Two-tone Base Abyss, Moons and tunes, Power packageMods: 20% tint, Reflective Black GrafxWerks Overlays, German Hella Horns, Hardwired Valentine One, red interior dome lights, custom cargo floormat, police scanner, ham radio, cellphone kit and a bunch of antennas on topWishlist: Rubber floormats, million dollars
no problemkinda related, has anyone tried the PermaCap?quote:PermaCap - The Permanent Gas Cap. Never remove it never lose it! No gas odors on hands! No twisting! No broken Nails! Fits most all cars with srew type gas caps! PermaCap has a unique spring flap for safe and easy dispensing of gas. Insert gas nozzle slowly through the spring flap. Reduces harmful fumes from escaping into environment. Lifetime warranty! Made in USA.
quote:ullbergm, would you really consider the perma cap????? seems rather fishy to me.....i probably wont get one unless someone else has tried it and likes it.i'm wondering if you wont spill *more* using the permacap..
quote:no problemkinda related, has anyone tried the PermaCap?I'm not too sure how the fuel system on the Vibe operates, but most newer vehicles require a tight seal on the cap, and I'm unsure if this product would hold pressure very well. I've been wrong before though.
quote:I'm not too sure how the fuel system on the Vibe operates, but most newer vehicles require a tight seal on the cap, and I'm unsure if this product would hold pressure very well. I've been wrong before though.i didn't know that.. i guess the permacap is a potentially bad thing then.. thanks
I have heard that in the Vibe a loose cap can cause the engine light to come on.
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
Quote, originally posted by L5K »I have heard that in the Vibe a loose cap can cause the engine light to come on. Any car built after model year 1996 could throw an engine light if the gas cap is loose.Quote, originally posted by NovaResource »Can someone remove their gas cap and tell me if the opening of the filler tube has a flap that covers the hole at the top. Every car I've ever owned with has a small flap that gets pushed out of the way by the pump nozzle. The flap is to prevent gas from splashing out. My Vibe doesn't have one. I wonder if it's not supposed to or if it's fallen off and down into the tank.No flap on mine.
