I just noticed my right headlight is out and I really need to replace the whole assembly because the lens is now completely opaque due to old age and the sun. Can anyone suggest a supplier to order from. I want the bulbs and all, and don't want to end up with an ill fitting aftermarket product. The car is a 2003 Vibe GT.
Have you tried using some of the haze removing products on the market? I use the "as seen on TV" Wipe New product and have great luck with it. The wet wipe is so potent and soaked with caustic solution that I usually prepare the headlights on all 3 of my cars before I tear open the wet wipe packet and I still end up having some leftover for the rear lamps.
