josholiver1 wrote:Thanks for the reply XRvibe10, I had a bi-xenon setup for my 03', had them aimed correctly and never got flashed. I really like your setup, perfect color temp. Did you remove your headlight for installation? There's hardly any room in there compared to my 03'.
Thanx 4 the set up comment - I love my whiteish/yellow look, I find the Yellow enhances the white low beams - No, I didn't have to remove the head lights - the snout on the fresh air tube for the air intake I removed to give me just a little more room to stick my hand in there (behind the driverside head light that is clipped to the rad cross support) - other than that a steady hand to carefully install the bulbs, the wiring and ballasts are a breeze
