Where to find oem headlight socket pigtail and how to wire it
Shrillcaleb153
Postby Shrillcaleb153 » Sat Mar 10, 2018 11:36 am
I'm looking for a headlight pigtail socket for my headlight. I think the wiring might be too sensitive to have one of those generic ones from auto zone. I need to find an original one. Or if someone can tell me what wires to match up with a generic one that would be great too!
Mark
Re: Where to find oem headlight socket pigtail and how to wire it
Postby Mark » Fri Mar 30, 2018 5:29 pm
I used a generic Auto Zone socket a few years ago to replace one of the ones on my 04. Sorry I don't remember the wiring, but it was easy to figure out with a simple volt meter. I probably found the right combination by searching on here, it's always the first place I search for Vibe questions.
'04 Base Frosty, '08 Base Stealth, '05 Base Satellite
niknik
Postby niknik » Mon Jul 09, 2018 9:02 pm
toyota 90980-11314
This is p/n of the connector for the headlight
SlammedNiss
Postby SlammedNiss » Mon Jul 09, 2018 10:20 pm
Shrillcaleb153 wrote:I'm looking for a headlight pigtail socket for my headlight. I think the wiring might be too sensitive to have one of those generic ones from auto zone. I need to find an original one. Or if someone can tell me what wires to match up with a generic one that would be great too!
Do you have HID or something? If no, it should only be 3 wires (low/high/GND) so it's not it's a fancy car that takes resistors to unlock/lock on the same wire. You should need a female 9003 (correct me if I'm wrong guys, I own a Matrix) plug like THESE HERE. Then just hold the plugs parallel to each other and match up the wiring. And use solder and heat shrink. Don't cheapen it with crappy connectors. Your headlights are an integral part of safely driving and deserve no less.
2003 Matrix Xrs Automatic
Postby zbyers » Tue Jul 10, 2018 9:28 am
SlammedNiss wrote:Do you have HID or something? If no, it should only be 3 wires (low/high/GND) so it's not it's a fancy car that takes resistors to unlock/lock on the same wire. You should need a female 9003 (correct me if I'm wrong guys, I own a Matrix) plug like THESE HERE. Then just hold the plugs parallel to each other and match up the wiring. And use solder and heat shrink. Don't cheapen it with crappy connectors. Your headlights are an integral part of safely driving and deserve no less.
You are correct H4/9003. Also second soldering and heat shrinking.
The trick question is, are we inquiring about a first gen (03-08) or a second gen (09-10)?
Ruby- 03 Salsa, Ray[is]AWD- 04 Salsa AWD, Simon- 03 Silver "Faux by Four"
Raven- 03 Abyss GT, Neptune- 05 AWD, Robyn- 07 Stealth Gray Metallic, Mystic- 09 AWD
GenVibe on Facebook, Everything You Need To Know About Vibes, Great How-To Index
Mark
Postby Mark » Tue Jul 10, 2018 6:13 pm
If I remember right the trick was getting the DRL/high/low wired correctly. I used a volt meter to compare with the other side. Then soldered, heat shrink and wrapped with tape.
Return to “Exterior”
Who is online
Users browsing this forum: No registered users and 1 guest
