What takeoffs wil fit an 08 base?
Yamahammer
Post by Yamahammer » Fri Nov 25, 2016 10:23 pm
I am trying to find another set of wheels for my 08 base to facilitate regular and snow tire switching. I have found some conflicting info as to what wheels from other cars will fit. Other than they be 16s so I can run stick tire size, I don't have any other requirements. So folks, what should I be lurking on Craigslist for? Thanks
07 grey Base 5 speed, 200k miles
MacGyver
Re: What takeoffs wil fit an 08 base?
Post by MacGyver » Sat Nov 26, 2016 6:06 am
I use this website to check tire and wheel sizes. http://www.wheel-size.com/size/toyota/corolla/2008/
Look for anything off a 2004-2014 Matrix or Corolla with a 1.8L engine. You can run 195/65R15 or 205/55r16. I and many others run 15's for winters
2009 Vibe Base
jayoldschool
Post by jayoldschool » Sat Nov 26, 2016 8:02 am
MKIV VW wheels work, too. Beetle, Jetta, Golf. Not the bigger Passat bolt pattern.
I also run 15s on my 04 in the winter (and 2014 16" Corolla wheels in the summer).
Yamahammer
Post by Yamahammer » Sun Nov 27, 2016 7:41 am
I found some steel wheels and tires that came off of an 01 Beetle. The bolt pattern seems to be the same, but I'm not sure about the offset. Anyone know if these should work?
jayoldschool
Post by jayoldschool » Sun Nov 27, 2016 10:20 am
LOL, did you read the post right above yours?
Yamahammer
Post by Yamahammer » Sun Nov 27, 2016 10:28 am
jayoldschool wrote:LOL, did you read the post right above yours?
Yes I did. I have read on here, however, that some VW wheels fit the bolt pattern but the offset is way different. I was just wanting to make sure they should fit before I drop the coin and drive 2 hours to pick them up.
NYfan08
Post by NYfan08 » Sun Dec 04, 2016 6:38 am
Where you located. I have my old steelies.
