19's on a 2008 Vibe, fitting questions help
Fatpaul
Post by Fatpaul » Fri Oct 28, 2016 6:39 am
see below
Jbenrod
Re: 19's on a 2008 Vibe, fitting questions help
Post by Jbenrod » Sat Oct 29, 2016 4:11 pm
I don't know how it would work but think it's too extreme and would just spend the money on a good set of tires or some other interior mod.
NYfan08
Post by NYfan08 » Sun Oct 30, 2016 10:59 am
Really depends on the offset. But I would say with an 8" width it would be pretty close, but then add the thickness of the adapters and I would think it wouldn't work. Like Jbenrod said just spend the money on a set of wheels that will fit without modification or adapters. There are plenty out there. I have 18"x7" on mine, and they fit well, but I also have a 40 series tire. General rule is you want to have the same circumference as the stock setup, so the bigger the wheel the lower the profile of the tires.
Fatpaul
Post by Fatpaul » Thu Nov 03, 2016 2:16 pm
Ok going a different route, what do y'all think of these? Fitment issues?
Owim
Post by Owim » Fri Nov 04, 2016 4:23 pm
I can't see the pictures, and the links aren't working for me either.
2009 2.4 AWD
melriv
Post by melriv » Wed Mar 01, 2017 1:30 pm
I got 18"s on my 2008 with 245/40's and the ride is definitely rougher however handles much better. I was told the 19"s are a much more expensive tire and also, that lower profile would be even rougher.
