VW wheels
xegwhts2uq
VW wheels
Post by xegwhts2uq »
Please ...What VW 16" wheels fit a 2007 Vibe.....Thanks
jayoldschool
Re: VW wheels
Post by jayoldschool »
Any MK IV wheels. Beetle, Golf, Jetta, etc. Not Passat (bigger bolt pattern). 15s, 16s, 17s, 18s.
Re: VW wheels
......but watch for the offset.
xegwhts2uq
Re: VW wheels
The add says off set 42,will that work? What about lug nuts?......Thanks
Re: VW wheels
Offset or back space determines the track width. our Vibes have regular offset, many VW have high offset. If you happen to get high offset wheels and put them on your Vibe the track will be narrower. you can get spacers to make up for it, but they are an added cost, and principally, I don't like the idea.
I am not sure what our offset is.
This website is helpful. It has a video on how to measure backspacing: http://www.roadkillcustoms.com/hot-rods ... z49b8lEmFi
If you search around you will find similar reference charts. This one i.e.: http://www.wheel-size.com/
jayoldschool
Re: VW wheels
Just check the offset and compare with the stock Vibe specs.
For lugs, you need conical seat lug nuts. Don't use the ones that come on Vibe alloys.
Here's a comparison:
