Got a set put on the Vibe earlier this week. Very happy so far, the ride feels much tighter and smoother and I was already quite happy with the Michelin Pilot Exaltos I just wore out.
yep, simply the best tire out there. I have had the Exaltos on the 2003 Vibe; very good as well, but the Primacy's are even better. I'm waiting for Costco to bring back their $70 off special so I can put them on the new Elantra Touring. I plowed through the 2 feet of snow in the Primacys with relative easy this past winter.
I checkd those out but the Yokohama YK520's were a better deal and just as nice of a ride. So far so good. Great to hear that you like your new tires!Have any pictures of them?
Thanks. I won't buy anything that is not listed on tirerack.com with consumer comments. I tend to do the same thing with Consumer Reports. I must say that I have not been steered wrong utilizing those research tools.
I looked up the MXV4s on TireRack and wow, them there are sum premium tars! In the size I use on my 17s (225/50) they were 175 or 206 American Dollars. Not quite sure what the difference between them is, since both were 93Vs. One had a wear rating of 440 and the more expensive one 420. I might be looking at the wrong ones. The Rack has MXV4s labled as Michelin Energy MXV4 S8. Since they have the 'Energy' name, do they help with MPGs?
I think the "Energy" line have low rolling resistance for better mileage. Although there are a line of Energy MXV4's they are different from the Primacy MXV4.Those tire rack prices you found were quite a bit more than I paid. Partly because the Energy line is a bit more and probably also because as "93V" they are V speed rated to (IIRC) 150mph. I got H rated (130mph) which should be fine for a base Vibe. Got mine from Discount.
Michelin's are great tires. I've read great reviews on these while I was tire shopping last week. They were a bit out of my budget so I went with YK520's too =/
These tires rock.......they are a "x-green" tire..been running these for over 2 years and the ride is so smooth and quite.would recommand these to anyone!
Quote, originally posted by lowincash »I wonder if these tires will be smooth on 18" rims...I guess if I want an even smoother ride I'll need to get smaller rims =/At least a taller tire. Are you running a 35 aspect ratio sidewall?
Quote, originally posted by lowincash »Mine is 225/45-18 right now. Not sure what you mean tho The tire place says I can go as much as 235/45-18 but I was afraid it might rub.With an 18 inch wheel, I figured you were probably running a 35 sidewall... but you're already on a 45... so that's about a comfortable as you could get in that size. I'm on a 225/50 17 and wish I had gone with a 55 side wall, but I was also concerned about the clearances around the wheel wells. A taller tire gives you more sidewall, and usually more cushion (Flex) while also allowing slightly less response. If you install a 16 inch wheel with a 60 aspect ratio sidewall tire (say a 215/60 16 tire) on your Vibe it would probably feel like you're driving on pillows... compared to, as an example, a set of 225/35 19s.
