If you need replacement OEM lug nuts and
awdVibeNoobie
Post by awdVibeNoobie » Fri Jul 26, 2019 8:06 am
don't want to spend a fortune for them (one parts store I stopped at was only pulling up the standard acorn lug nuts. Another parts store was able to find the correct ones but at $10 a piece, I laughed and walked out the door)you can buy them from here for a much more affordable price.
03 awd Vibe my backup vehicle
Re: If you need replacement OEM lug nuts and
Post by zbyers » Mon Jul 29, 2019 2:58 am
They can be had much cheaper on ebay or simliar websites.
https://www.amazon.com/TOYOTA-FACTORY-N ... 8735&psc=1
'74 Thing, '79 El Camino, '83 VW Vanagon DoKa '91 Vanagon,
'04 & '06 CRV, (2) '03 Base, '04 GT, '06 AWD, '07 Base, '17 Frontier CCLB
awdVibeNoobie
Post by awdVibeNoobie » Wed Jul 31, 2019 12:33 pm
Your link isn't working. Gosh I forgot to check on amazon, oh well. The ones I bought from the link I provided doesn't have the chrome cap which I was looking for. I find it ridiculous that parts store wants $10 per lug nut. I hate to see what the dealership would charge.
Bookworm
Post by Bookworm » Wed Jul 31, 2019 3:53 pm
Here's a direct search with those keywords. (It is a dead link. Looks like it was pulled VERY recently)
https://www.amazon.com/s?field-keywords ... 8BLACK+%29+
Post by zbyers » Thu Aug 01, 2019 3:15 am
Strange that link died like that... I literally posted that just after searching lol.
ZZvroom
Post by ZZvroom » Fri Dec 20, 2019 8:09 pm
2003 GT
I'm seeking replacements for the lugnuts on my new pride and joy.
The existing ones seem to have a chrome sheath of some ilk and they deform from the socket.
I seek replacements to fit the fancy wheels. I can live without the chrome to be sure I can get them off when I must.
Post by zbyers » Mon Dec 23, 2019 4:05 am
ZZvroom
Post by ZZvroom » Fri Dec 27, 2019 6:07 am
I have the unsteel swirly wheels on the GT; would those be Aluminum or Magnesium?
Post by zbyers » Fri Dec 27, 2019 6:21 am
If you have this wheel (or the optional 17" that is similar to this), you need the flat lug nuts.
OEM 16 Inch Rim
OEM 17 Inch Rim
If you have this wheel, you need the acorn lug nuts.
OEM 16" Steelie
Essentially the difference comes down to the mating surface. On the steel rim, it is a conical/tapered seat. So you need a lug nut that works with that too.
On the alloy rim, as the first picture, the mating surface of the lug nut to the rim is flat. Because of this, you need the flat (commonly called mag) lug nuts.
ZZvroom
Post by ZZvroom » Sat Dec 28, 2019 8:32 am
Thanks. I'll look at flat ones with a deep post for the socket.
Cookie
Post by Cookie » Thu Feb 13, 2020 9:28 pm
I found a set at my junkyard for my OEM steelies. They let me have em for free granted I was buying some other parts as well.
07' Pontiac Vibe Salsa Red
Vulcan
Post by Vulcan » Sat Jun 13, 2020 8:51 am
I just ordered a set of flat, mag style.
I can't even get the wheels off my Vibe, the lugs on there are so mismatched and mangled from impact wrenches I don't dare until I've got a full new set of them onhand. Even then, there's at least one lug nut so rounded I might need professional help with it. It looks like maybe a 23mm hex will grab it, but I don't yet have a 23mm. Some of them, the 7/8ths fits best, most of them seem to be 22mm.
2006 AWD, 190k
Post by zbyers » Mon Jun 15, 2020 7:39 am
OEM lug nuts are a 21mm. Your best bet might be to buy one of these.
https://www.amazon.com/AMPRO-T72038-Eme ... B00A4AIRCO
03basevibesalsa
Post by 03basevibesalsa » Thu Sep 03, 2020 2:03 pm
2003 base 4 speed auto FWD
If it ain't broken, don't attempt to fix it and in turn end up breaking it
