inside tire wear=-
jamesmetairie
inside tire wear=-
Post by jamesmetairie » Wed Jun 20, 2018 5:36 am
05 base vibe, 124,000 miles on it., automatic tranny.
running bf goodrich touring t/a,s from sam,s club.
maybe 20,000 miles on these tires.
about psi 33 on all 4 tires.
rotate regular.
divers side , rear tire showing wear only on the inside.
assuming there is no parts worn out and no damage to the suspension
what,s the usual cause of such wear?
how many miles do you guys usually get out of the original struts front and rear?
as always, thanks to all for any advice.
Re: inside tire wear=-
Post by Caretaker » Wed Jun 20, 2018 6:39 am
According to the Bridgestone website, it is usually your toe and/or camber are out of spec. When is the last time the car had an alignment, which is even more important if you live in a northern climate (which you don't) where freeze/thaw take a huge toll on the roads?
I had T/A tires once. The worst I've ever owned. Uneven wear turned into the loudest tire noise I have ever experienced. If you find yourself needing tires from Sam's again, get the General Altimax R/T 43
Live it up: There will be plenty of time to be old when you die.
** 2009 Vibe: 1.8 liter automatic **
** 2010 Hyundai Elantra Touring **
** 2007 Honda Fit Sport **
Post by zbyers » Thu Jun 21, 2018 3:13 am
Caretaker wrote:According to the Bridgestone website, it is usually your toe and/or camber are out of spec. When is the last time the car had an alignment, which is even more important if you live in a northern climate (which you don't) where freeze/thaw take a huge toll on the roads?
I agree with caretaker. Take it in for an alignment and see. Also highly recommend the Altimax RT43. Great treadlife, QUIET, smooth riding tire at a reasonable price.
Ruby- 03 Salsa, Ray[is]AWD- 04 Salsa AWD, Simon- 03 Silver "Faux by Four"
Raven- 03 Abyss GT, Neptune- 05 AWD, Robyn- 07 Stealth Gray Metallic, Mystic- 09 AWD
GenVibe on Facebook, Everything You Need To Know About Vibes, Great How-To Index
jolt
Post by jolt » Mon Aug 13, 2018 11:01 am
Besides alignment, it could be related to worn shocks and/or balance problems on tire. This would depend on the type of wear or wear pattern that is seen on the tires.
jamesmetairie
Post by jamesmetairie » Sat Aug 25, 2018 5:19 pm
thanks to all 3 of you guys.
I appreciate it.
