Interchangeable Rims?
bikejon
Postby bikejon » Tue Nov 13, 2012 4:21 am
I am trying to find a pair of steel rims for my 03 Vibe, but they're either impossible to find or too expensive.
I know Matrix rims are the same, but I thought someone said Corolla rims can be used too.
Does anyone know anything about this?
Scwmcan
Re: Interchangeable Rims?
Postby Scwmcan » Tue Nov 13, 2012 5:40 am
Yes for the first generation vibes, and for the base 1.8 l 2009+ Vibres, Corolla wheels will work just fine.
bikejon
Postby bikejon » Tue Nov 13, 2012 5:45 am
Awesome! Mine is a 2003 which was the 1st year if I'm not mistaken.
bikejon
Postby bikejon » Tue Nov 13, 2012 8:16 am
Actually, the Corolla rims I see online are all 15". The Vibe rims are 16"
SeattleJeremy
Postby SeattleJeremy » Tue Nov 13, 2012 12:24 pm
The Corolla 15" wheels fit the Vibe.
However, the 14" wheels do not fit.
Toyota Celica and Scion tC wheels fit too.
06 Vibe Base - Mono Platinum - Manual
bikejon
Postby bikejon » Tue Nov 13, 2012 6:52 pm
But my tires are 16"
Scwmcan
Postby Scwmcan » Tue Nov 13, 2012 7:58 pm
I take it you mean that you want to use your old tires with the "new" rims, in that case you will need to try to find 16" rims from a corrolla which I am pretty sure would be after market. Depending on how old your tires are it may be cheaper to get new 15" tires and rims, but of course we don't know what shape your tires are in so can't really comment too much on that.
Postby KITT222 » Tue Nov 13, 2012 8:34 pm
Wheels with a bolt pattern of 5x100 (5 lugs, 100mm spacing) will also fit. I have rims from a PT Cruiser on my Vibe right now. Other wheels that would work will be certain VW's, GM compact FWD cars per-Cobalt (Cavalier, Sunfire, Corsica, etc), Dodge Neon (including SRT4), and several others. Just search "5x100" on Craigslist.
Postby trb » Tue Nov 13, 2012 9:01 pm
Ditto on the craigslist search. As long as the backspacing is about 40mm and the center hole is the same size for the hub, they should fit fine. Also look on http://www.car-part.com and you might find some close to you. Yes, the Vibe and Matrix are the only ones with the exact same wheels, 16"x 6-1/2", so if you need to replace just a couple, you will have to buy only Vibe or Matrix wheels. One thing to consider, the places on car-part.com also can ship their parts across the country. Prices for the wheels start at $25-30 each and up. Shipping would run probably $25-30+ each.
Corollas did have a few alloy wheels in the 16" size, but they are going to run $75-100 each plus shipping.
FWIW, I bought a set of 17" Vibe alloy wheels from two sellers on ebay for a grand total of $230 shipped. But it did take me a month to find them and buy all 4 wheels.
Here are some of the 16" alloys on ebay for $65 each shipped as long as you are in the US. It doesn't say they have all 4 so you might ask. If so, that is a good deal as long as it includes the center caps too.
http://www.ebay.com/itm/03-04-05-06-07- ... 93&vxp=mtr
There are a few others on ebay for a bit more. If you just need a pair, maybe you could buy two now and get the other two later.
Good luck!
bikejon
Postby bikejon » Wed Nov 14, 2012 4:18 am
Thank you very much guys! I will start with carpart.com.
I just bought two new snow tires. I want to mount them on their own rims so I can just swap the wheels rather then the tires.
I did this a couple years ago and had no trouble getting steel rims locally for $50 each. Now I can't find them.
But this info helps.
Scwmcan
Postby Scwmcan » Wed Nov 14, 2012 7:33 pm
Okay, but I hope you are running four snow tires, it really isn't good to only run two as the differences in traction can do weird things. You would be much better off with all four.
bikejon
Postby bikejon » Thu Nov 15, 2012 4:24 am
Yes, these two are replacements, rounding it out to 4 snows
thebarber
Postby thebarber » Thu Nov 15, 2012 8:34 am
ive got 15's from a jetta on mine...
gave1002
Postby gave1002 » Mon Jan 08, 2018 8:56 am
thebarber wrote:ive got 15's from a jetta on mine...
Do you know the offset of those Jetta wheels?
Return to “Wheels & Tires”
Who is online
Users browsing this forum: No registered users and 1 guest
