Joshuaeb09's Platinum 09 GT (Added Exterior Lighting and Amp pics)
DressedInBlack
Re: Joshuaeb09's Platinum 09 GT (joshuaeb09)
Post by DressedInBlack »
nice "broken-in" header colors! man, oh man. you sure do have an awesome setup.where did you get that license tag light? ive wasted money on a few different ones that didn't fit in the housing or were not anywhere near 6000k.
http://
joshuaeb09
Re: Joshuaeb09's Platinum 09 GT (DressedInBlack)
Post by joshuaeb09 »
These look just like the ones I have (I got 2 so I have a spare)http://cgi.ebay.com/ebaymotors...ories
2009 Silver Vibe GT AutomaticI/H/E/Unichip @ 93octaneMy Garage : http://forums.genvibe.com/zerothread?id=43521" onclick="window.open(this.href);return false; - Gone (Sold)
2005 Expedition Limited 2WD|4R75W 4SPD Auto|3.73 Gears|I/E|5Star Tuned@ 91|3" Lift/Level - Current Ride
A Psycho Martyr
Re: (joshuaeb09)
Post by A Psycho Martyr »
1st time I've looked in your garage....I'm impressed w/ the header And the subs' setup is killer. I like that enclosure
joshuaeb09
Re: (A Psycho Martyr)
Thanks!,Yea the enclosure is sweet. Its actually a carry over from the Expedition I had before the Vibe, couldn't let it go. I figured if it was enough to give a fully loaded Eddie Bauer roof flex it should do nicely in the Vibe... lolI need to update the pic tho as now its facing the back and all the wires are cleaned up. It gets pretty f***ing loud especially when it drops low. I was actually fairly impressed when I moved it over to the Vibe.
A Psycho Martyr
Re: (joshuaeb09)
haahaa...I was the same way when I put my 2 15's in.Does your windsheild flex alot?
joshuaeb09
Only towards the top and middle. Although my rearveiw is unusable and my phone holster (uppermost left corner) shakes uncontrollably. My beltronics display also gets fuzzy and some times it does a little dance on the dashboard lol. But my favorite is the added benefit of free massage chairs
NascarXprt
Re: (joshuaeb09)
Post by NascarXprt »
man ive gotta see this beast in person!
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
DressedInBlack
thanks for that link, Josh! Quote, originally posted by A Psycho Martyr »Yep, the massage chairs are nice i played a Chemical Brothers song that has a huge bass sweep and my mum asked me to "play that massage song again!"
http://
joshuaeb09
Re: (NascarXprt)
Quote, originally posted by NascarXprt »man ive gotta see this beast in person!lol Never heard it referred to as a beast before.
bigdaddyjosh
Re: (joshuaeb09)
Post by bigdaddyjosh »
I love the look...That being said, I do have some thoughts. What is the purpose of a giant sub box in a hatchback. You can't haul anything, unless you take it out. Do you have a second vehicle?
Pioneer AVH-P8400BH HU Polk Audio DB-6501 Components Pioneer GM-6400F Amplifier K&N drop-in filter Fiberglass Sub box w/10" Cerwin Vega
joshuaeb09
Re: (bigdaddyjosh)
Quote, originally posted by bigdaddyjosh »I love the look...That being said, I do have some thoughts. What is the purpose of a giant sub box in a hatchback. You can't haul anything, unless you take it out. Do you have a second vehicle? The sub box takes all of 5 minutes to pull out, and I didn't really buy it for the space. I mainly bought it cause I got a pretty sweet deal on it and I was able to turn it in a pretty fun car to drive. Plus my folks only live 30 minutes away so if I really need to haul something I just borrow one of my dads trucks.
joshuaeb09
Re: (joshuaeb09)
Well Guys I took the plunge and ordered the NST Pulleys for the Scion Tc. 20% Underdrive Crank, Lite WP, and 20% Overdrive ALT. I am anxious to see how they perform once they come in and I can get them on the car. I'm starting to run out of performance mods this might possibly be the last one. lol
blackrayne
Re: (joshuaeb09)
Post by blackrayne »
Quote, originally posted by joshuaeb09 »To do the map lights I actually removed the whole assembly and wired in my own LED's. However the bulb size is 194 and you can remove the clear lens with a small flat head screw driver. Just gently pry around the sides until it starts loosening up then you should be able to pull it off. The bulbs are a pain to get out but DO NOT twist them it will cause the whole socket to come off and it will get stuck up behind the housing. To remove the bulbs i would recommend wiggling them side to side until they give. So I just found out the hard way about *not* twisting the dome lights to remove them. How did you remove the whole assembly? I seem to have a loose dome light floating about up there now and we can't figure out how to get the assembly to come out to retrieve the light.
November, 2011 VOTM!
joshuaeb09
Re: (blackrayne)
Quote, originally posted by blackrayne »So I just found out the hard way about *not* twisting the dome lights to remove them. How did you remove the whole assembly? I seem to have a loose dome light floating about up there now and we can't figure out how to get the assembly to come out to retrieve the light. Very carefully. It basically pulls straight down but the clips can brake. I got a broken one and it rattles a little now. Grab it from the front(side facing the windshield) and try to finesse it down. The clips are on the 4 corners and a PIA to get out.
joshuaeb09
Re: (joshuaeb09)
UniChip Update: Retuned for 2009 Scion TC I/E @ 91. I slammed the gas with T/C and A/C off and I didn't move for a second . Not sure what was louder bouncing off 6.5 K or the tires Also my Pulleys came in save the Alt pulley . Anxiously waiting so I can install em.
joshuaeb09
Updated mod list and added a pic of my new Cerwin Vegas!
A Psycho Martyr
lovin the interior ledsI know how hard it is to actually capture how bright they arebut I can tell those are definitely doin what they're supposed toWhat brand are the leds? Those things are pretty bright.
joshuaeb09
The glow are just some cheap imported 30 led strips off of ebay. The ones in the map lights are 2 3x2 Arrays in each that I put together. The other dome lights are some cheap 4x2 5050 SMD boards off of ebay as well.
DressedInBlack
are all of the pulleys installed?
http://
joshuaeb09
Re: (DressedInBlack)
I do not recommend grabbing the underdrive pulley or the alternator pulley. The underdrive pulley, while it fits, has some serious belt tracking issues with out 2AZFE belt configuration(I tired a large number of different sized belts). The OEM alternator pulley is a decoupler pulley so installing the overdrive alt pulley(solid piece) gave me some belt squealing at shift points . If you do want to go with a pulley I would recommend the CR-LITE pulley from NST it is the same size as the OEM crank pulley so you shouldn't have any belt issues. I have yet todo so as with my recent promotion may be passing the Vibe off my my bro and getting a new toy.I am also fairly happy with the I/H/E tuned @ 93 Octane. It is definitively more powerful than stock, as my tires can tell you
DressedInBlack
Re: (joshuaeb09)
that blows! sorry to hear the pulleys weren't cooperating.and you sound like a cool brother!!
http://
joshuaeb09
Well its official the Vibe is passing on to my bro. Found a sweet deal on an 05 Expedition Limited fully loaded. While I will miss the Vibe nothing rides quite like a 2.5ton luxury SUV .
DressedInBlack
Re: (joshuaeb09)
Well there goes one of my favorite Vibes on this forum!Don't be a stranger. And have your brudda join the GenVibe family!
http://
2010GTJT
Re: Joshuaeb09's Platinum 09 GT (Added Exterior Lighting and Amp pics)
Post by 2010GTJT »
Hello, did the Unichip address any CEL's you had from the header install? What p/n was the header or what year TC header did you use that worked?
BenWA
Re: Joshuaeb09's Platinum 09 GT (NascarXprt)
Post by BenWA »
joshuaeb09 wrote:By popular demand ... lol. I have refreshed the PICs including my New 3000K fogs. I also installed an O2 sim to get rid of those pesky P0420 codes from not having a pre cat.
They are still broken for me.
2003 Vibe Base A/T
Unfortunately, this member passed the Vibe on to his brother a few years ago and hasn't posted again since, so I wouldn't expect a response :|.
BenWA
Post by BenWA »
vibenvy wrote:Unfortunately, this member passed the Vibe on to his brother a few years ago and hasn't posted again since, so I wouldn't expect a response :|.
Oops. I didn't notice the date on that message. :lol:
2003 Vibe Base A/T
