Sunroof Noise
saweetlou
Sunroof Noise
Post by saweetlou »
I can hear a air leak when Im doing highway speeds so much so that I have to close the cover to drown it out. Has anyone had this problem before. Its not leaking any water at least that I can see.
Re: Sunroof Noise
Negative here .... BUT we have two 2009 Vibe GT's with sunroofs. What year are you talking about? More info please.
2014 Silverado, 2004 Vibe GT
Re: Sunroof Noise
The screws that hold the sunroof glass to the frame may be loose causing the air leak. There is one in each corner (4 total) of the sunroof glass. They should be torx screws.
Re: Sunroof Noise
My glass was not completely flush with the metal roof. I loosened a bolt or 2 and adjusted the glass. Check yours and inspect the rubber surround closely.
