Matrix vs Vibe Window Regulator?
Fever
Post by Fever »
Does anyone know if the Matrix manual crank window regulator will fit the Vibe? 2007 Vibe base, front left (drivers) side.
Rockauto has Matrix manual crank regs but they only list power regs for the Vibe.
Thanks.
Fever
'07Vibe '13FR-S '99Ranger
sideshowalan
Re: Matrix vs Vibe Window Regulator?
Post by sideshowalan »
Can't tell you for sure that it works as I've never held them in my hands.
But from my experience with interchanging parts between matrix & vibe (suspension, door lock actuator, interior pieces).....if it's a mechanical part it will work.
Only differences between the two are exterior metal and the radio.
2008 Pontiac Vibe
2008 Toyota Sienna XLE
They are probably the same. I know someone on here put Corolla power parts in their manual Vibe, and I doubt there is any difference between Corolla and Matrix parts. I put a Corolla rear door latch on my Vibe and that worked, but I didn't look at the window regulator, but it was power and not manual.
Oh, and the AC systems are different between the Matrix and Vibe also.
Fever
Post by Fever »
Thanks for the input sideshowalan and trb. I suspected as much but was looking for confirmation. I'm going to order the Matrix regulator and see how she goes.
