I would say probably not directly, but you might get lucky. I'm assuming you have the 03? Maybe someone with an 09-10 can measure the distance between the bolts and then you can compare them to yours. I would do it if I still had my 2010 GT.
And another question is if they actually mount the same way in the rear. Most cars have two bolts in the front, but there are often differences in the rear mounting between different models.
Worst case scenario, you might use the 03 seat tracks and just bolt the 09 seats to them. I know others that have done this with other car models successfully. To make sure it would bolt up easily, you would need to compare the seat track mounting distances where they bolt to the seat on both types.
Good luck!
